I just installed a kenwood dnk7140. Everything is working fine, but I cant get my subs on. Ive checked the subs and the external amp everything seems to be fine. Ive been told that Kenwoods sub preouts can be tricky to function. Any ideas? Thanks
Have you checked to see if the sub amp is turning on. Check to make sure you have at least 12 volts on your power as well as your remote turn on (Blue/White on radio harness).
If everything is hooked up correctly, it is possible that the preout is turned off. Some headunits have selectable preouts. If so you should be able to turn the sub on and off in the menu.
Hope this helps
VOTE
