Cars & Trucks Logo
Posted on Mar 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Heater fan motor quit working already checked all fuses and relays
Marvin
Level 3:
Top Expert:
  • GMC Master 85,242 Answers
  • Posted on Mar 08, 2010
Marvin
GMC Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29057657
Points
266281
Check the fan switch in the dash and the fan motor connector for burning, if u find burned connectors replace them and the heater blower switch.
1helpful
Heater fan just quit working
Someone will need to check for voltage and ground at the motor. Could be a bad motor, resistor, relay, switch, or fuse.
Heater fan stopped working
The fan will not quit completely if it is the resister, Did you check if a fuse is Blowin? Or the relay is defective, The blower motor could be shot , They don,t last for ever,. If resister is bad one of the speeds for the fan mostly quits working,
Heater blower motor doesn't run
check under your dash by the fuse box might be there
4helpful
The heater fan motor quit on my 2002 Ford F-150 Super Cab and I can't find a fuse for it. How do I repair it?
Owners manual lists the fuses as :
Engine compartment fuse # 105, 40A
- This is the power to the blower motor relay to drive the blower.
Cab Fuse Panel, Fuse #22, 10A. This is the power to the switch in the HVAC panel.
- This fuse through the switch to operate the relay coil on the blower motor relay.
The other thing to check is the blower motor resistor, to see if there is any damage to it ( usually this is the blower only works on high )
This is behind the glove box
6answers
My heater fan as stoped working on my bmw320 d it has climate control but all lights are fine
Hello There
I'd suggest looking at the fuse to start with, This is the cause in most cases.
Hope this helps
A/c or heater not working
you may have to reprogram pcm. there is a TSB on this. call dealer to confirm
2answers
The heater quit working and the panel wont light up on a 1992 Chevrolet pickup
check the "blower motor fuse" "heater fuse" and ac fuse and relay. these will be located under the dash on the drivers side usually mounted near the foot rest next to the door AND under the hood along the fender on the passenger side.
Heater Fan
Hello! Answer below was given to a similar problem.
"The unit is located under the dash mostly on the passanger side. You might have stripped the fan from the motor...does it run at all? can you hear it but no air comming out?
You might wanna get a repair book and look up where the relay's for the fan and motor are located."
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
