Good used one is fine and less dinero TV Parts Universal TV Stands DLP Chips ShopJimmy
SOURCE: Samsung LCD TV shut off, wont turn back on...?
My samsung lcd is doing the same thing, and I have been told that the power supply is bad. But apparently samsung won'r sell you one.
SOURCE: My samsung tv turns on and off repeatedly at
Mine was doing that then it quit even turning on so I replaced the 4 Capacitors today on the power supply board that had bulged up on the top 3 had split open they where on the top right corner of the board where the ribbon jumps from the power board to the main board with ones from Jameco Part Number 606521 they worked perfect but make sure you put them in with the correct polarity easy to do just keep an eye on it. Very simple repair and took me about 30 min to take itapart solder on the new ones and put it back together all for under $10.
SOURCE: Same "clicking" problem with 46" Samsung LCD...does not turn on.
With any luck you will have the same problem asa the rest of us : blown power board capaciters , remove the rear cover {20 screws} look in the middle of the back of the set with the cover {5 screws} removed from the power supply . Now look to the upper right cornerof the board in the middle of the tv there may be 1 or several capaciters leaking from the X shape on the top , this be be your problem match up replacements but source units that have a higher max voltage than 10volts 7 get them soldered into the board . I repaired mine that failed at 16 months for $4 in parts & it took longer to remove the screws than it did to affect the repair. If you are not conifident about soldering on your $2000 tv then take the board to someone for the job to be done , I would not advise this as a first soldering job , good luck I can't belive how common this is Samsung needs to step up ......
SOURCE: 46 inch Samsung TV that just clicks but wont turn on
I just fixed this very same problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
SOURCE: Samsung 26" LCD TV will not turn on
you have one or two bad caps in the power supply these can like devices will be puffed on the top from venting the value is wrtten on the sides replace them and you will be good to go
