Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
Posted on Mar 08, 2010
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
SONY TV WILL NOT STAY ON.STAYS ON FOR A FEW SECONDS THEN TURNS OFF BY ITSELF.HAS LINES ACROSS SCREEN.
Anonymous
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Mar 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
2916
Points
10
Sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
What part is needed to fix colored vertical lines across entire screen of Samsung tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
7helpful
MY sony trinitron XBR TV does not stay on.
what's wrong with my Sony trinitron XBR tv's timer
2helpful
2answers
Mitsubshi ws-55311 turns on and then turns itself off
no, if blink code the problem is in the TV set--cable will not cause this type of trouble
Tv turns off when I first turn it on
hi this s grizmofreak
solution to above problem
this s because of the secondary emissions of picture tube, and once the supply stops the emmissions from the picture tube wont stop for few seconds and horzontal scannin problem.
please do rete me on the above solution.
RED SCREEN
hell yeah,
the biggest mistake I did with this tv.all tubes need to be replaced and it burns a hole in ur pocket.no guarantee on tubes,sony aware of the problem but didnot recall these defective sets.
good luck.
nanz
Sony KP-65WS500 65 in.
Check your CRT boards on the end of the tubes for burn spots, and burnt components, check the resistors to make sure they are not shorted, burnt, and they read the correct resistance. Check the diodes to make sure they conduct in one direction only and are not shorted or open.
4answers
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Orange screen...shuts off after 3-5 seconds
I will tell you in a week... I just dropped mine off to a repair guy. Mine is doing the same thing... probably not the same model though.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
