If Shooting in Auto, flash will come on when camera senses it needs it. If you want it on and still want to shoot in auto, move dial to M or P or other manual mode. The press the flash pop up button on left of the flash and turn dial back to Auto. Now you can use the flash when you want to and still use Auto.
In the point&shoot modes the camera decides whether to use the flash or not.
In the advanced modes (PSAM) you decide whether to use the flash or not. To use the flash, press the flash button at the base of the prism and the flash will pop up. When it's charged up the flash icon will light, and you can shoot. When you don't want to use the flash, press the flash down until it latches.
If u select mannual mode u have to press flash button,whitch is on left side below flash unit,if u select auto mode, flash itself elect when u half press the click button.
SOURCE: Nikon D70 (Control Panel.)
This is a known problem that is being repaired FREE of charge by Nikon. Go here for a form to fill out: http://www.nikonusa.com/email_images/nikonusa/service_advisory/d70.html
SOURCE: nikon D70 flash doenot fire
According to my information, the camera may need a new flash PCB (printed circuit board). Check the repair service search on this site for someone in your area. The part number for the circuit board is: 1S014-020-1 and runs about 50$
SOURCE: Nikon D70 On/Off switch will not turn the camera off.
Hi, The problem with your camera is the power switch under the top cover needs to be repaired Or replaced by a camera repair tec, I have repaired this problem many times, Not a quick fix.
