Question about Pentax ZX-50 35mm SLR Camera
THE SHUTTER STUCK OPEN AND NOTHING HAPPENS, EXCEPT FOR IT SOUNDS LIKE A MOTOR IS RUNNING . IF I PUSH ANY BUTTON THE MOTOR RUNS. THE SHUTTER HAS CLOSED.ITRIED REMOVEING THE BATTERIES AND PUTTING THEM BACK IN. I have a Pentax zx-50 SLR camera
    Master:
  • 411 Answers
Loader gear broken,get it replaced ,get it done by a camera tec.
Posted on Mar 08, 2010
    New Friend:
I HAVE A 35MM PENTAX ME CAMERA AND IT APPEARS THAT THE SHUTTER IS STUCK. WHEN I MOVE THE APERTURE SETTINGS I SEE THE OPENING MOVING BUT LOOKING THROUGH THE VIEW FINDER IT IS TOTALLY BLACK. WOULD I NEED A NEW BATTERY?
Posted on Sep 08, 2010
6ya staff
SOURCE:
My shredder runs non stop, when I insert paper to shred , it stops... I push reverse, it works , pull paper out and runs non stop.......
Sounds like a bad or stuck sensor, acting as if it is always seeing a peice of paper in it. Check if you can find it and maybe it is just stuck to the on position..
Nov 07, 2013 | Omnitech 10-Sheet Micro-Cut Shredder
DIshwasher stopped during wash and won't run or drain.
Sounds like a drain motor startup capacitor, or stuck pump. Try disconnecting power and turn the water pump manually. Some disassembly required. Then after a few good hand spins replug and try again.
Mar 05, 2010 | Kenmore 24 in. 17022 Built-in Dishwasher
My rca rs 2657 cd changer is stuck. door will not open. any ideas how to correct?
If you hit the open button and you hear a sound like a motor running than it is most likely a belt or connection that physically opens the tray. You'll have to take it apart, locate the cd player and check from there. If no sound of a motor running when the button is pushed then the motor is probably bad.
Oct 17, 2009 | RCA 100-Watt Stereo System With 5-CD...
Our PLD4375RFC2 dishwasher fills up with water but doesn't run
no their is no fuse. sound to me like your motor is not working, however
the pump should still drain out.push cancel only and unit should drain if it does then id say motor bad. you can try to take apart and check motor blade ive seen toothpics, food , other objects hold motor impeller from turning making it seem like its the motor but actually its just stuck..remove btm wash arm and filter cover thentake two or 3 small screws from a plastic cover covering motor impeller, look to see if anything is in their if so remove. warning if you see a white ball down their leave it alone reinstall and see what happens. hope this helps.
Sep 17, 2009 | Frigidaire PLD4375RFC Dishwasher
Same problem with Canon S2IS - Image is black, getto fix no longe
I had the same problem here in America and had a run around from Canon, but they finally took my S2 IS in for a checkup and found the problem so many S1 IS and S2 IS had with the symptoms you have. It was the shutter sticking. Mine was only a few months out of warranty and they did a free one time courtesy repair they say. Many in other countries have to pay to get it repaired. Canon should have recalled it as they did on the S1 IS. They did not! The way to know it is a sticking shutter is to look down the lens with something to magnify the opening and you will see the shutter stuck closed and nothing happens except the shutter sound. The display shows a blank picture taken. All menus worked fine. There is a forum about this with hundreds of Canon owners frustrated about it.
Sep 05, 2009 | Canon PowerShot S2 IS Digital Camera
When start button is pushed, hums but does not run. Drum does not turn. Belt is okay
It sounds like it is the motor or a stuck/obstructed blower wheel. You can start by opening the door, push the door switch in, hit the start button & see if you can turn the drum clockwise by hand. This might get it going. if the drum does not move by hand then the problem is probably within the blower. post your findings for a follow up
May 01, 2009 | Dryers
Dryer wont run/push power-sounds like it wants to start/nothing
i get this all the time,yes it is the motor,what happens is the motor gets so weak that it will no longer turn the drum it just hums,a motor on ebay runs about $65,your model number if you want to tackle it is inside the dryer door-mike
Apr 24, 2009 | Dryers
Shutter stuck half open
This sounds like the mechanism has worn. It is a straight forward service centre procedure, I wouldn't recommend trying to do anything that will make it worse. Leave it to Nikons engineers.
Mar 11, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
CD Player shelf will not open.
the door could be stuck or the cd laser mech. is stuck or the power circut for the motor that opens the door or the motor has become weak or ect..... there are many posibilitys but you need to listen for the motor sound or a click when you hit the button , if you do hear it then its stuck or the motor is to weak and needs to be replaced , or the circut isn't giving enough power to the motor
Oct 03, 2008 | RCA RS2664 Shelf System
Pentax ZX-50 35mm SLR Camera Logo
665 people viewed this question
Top Pentax Photography Experts
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
