Panasonic KX-T7730 Corded Phone Logo
Posted on Mar 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Address storage How can we store telephone numbers?
Anonymous
Level 2:
  • Expert 113 Answers
  • Posted on Mar 29, 2010
Anonymous
Expert
Level 2:
Answers
113
Questions
0
Helped
134559
Points
351
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308/824 system. From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00.
3. Enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial.
4. Press AUTO DIAL / STORE to save your setting.
5. To go to the next speeddial location press SP-PHONE and follow steps 3 and 4 again.
6. Press PROGRAM to exit program mode.
7. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
2answers
Esprit EL 255 Motor Error
http://www.spiritfitness.com/servicedocuments/pdfs/_0002_ESPRIT/_0002_ESPIRIT_02_Ellipticals/003_OwnersManuals/2010_ESPRIT/EL255_OwnersManual_255009.pdf
2009 manual so may be difficult to find a support telephone number that works for that model, but the web site above has a free manual. The main web site has a support email address, telephone number, and Store Locator for you to pursue an answer.
http://www.spiritfitness.com/residentialownersmanuals.html
[email protected] ' 870-935-1107 ' Store Locator
1helpful
2answers
I have registered my Brother MFC 9840CDW on the brother website but it still says "not registered" when I try to email a scanned document. I registered it online. Do I have to do anything on the...
If the LCD shows Not Registered when you enter a One-Touch or a Speed-Dial number, it means that an email or number is not stored there.
If you selected E-Mail and save the E-mail address, you can only use the E-mail address when you are in Scan mode. If you selected IFAX and save the E-mail address, you can only use the E-mail address when you are in Fax mode.
Your machine has 20 One-Touch keys where you can store 40 fax or telephone numbers or E-mail addresses for automatic dialing. To access numbers 21 to 40, hold down Shift as you press the One-Touch key
You can dial in any of the following ways.
Manual dialing
Use the dial pad to enter all the digits of the telephone or fax number.
One-touch dialing
Press the One-Touch key that stores the number you want to call. (See Storing one-touch dial numbers on page 60.)
To dial One-Touch numbers 21 to 40, hold down Shift as you press the One-Touch key.
Speed-dialing
Hold down Shift as you press Search/Speed Dial, and then enter the three-digit Speed-Dial number. (See Storing speed-dial numbers on page 61.) Three-digit number
8helpful
I need to know how to program the numbers into the speed dial option. My mother's phone is a table set with large numbers #29267A ... close enough?
Before you store a telephone number in memory, make sure the dialing mode is
correctly set for the type of service you have. The default dialing mode is tone
(touch-tone), so if you have pulse (rotary) service, you must first change the dialing
mode. See “To Set the Dial Mode.” The following buttons can be stored into any
memory location: 0-9.
STORING FREQUENTLY CALLED NUMBERS
1. Pick up the handset.
2.Press the store button.
3. Push the desired memory location button.
4. Press the store button.
5.Use the handset number keys to enter the telephone number (up to 16-digits)
and press the store button.
6.Hang up the handset.
NOTE: If you make a mistake, use the delete button to delete wrong digits.
CHANGING A STORED NUMBER
Repeat the storage sequence above. The new number replaces the old number at
the memory location.
ERASING A STORED NUMBER
3.Press the memory location (0-9) to be erased.
4.Press delete for three seconds until the number in the display is erased.
5.Hang up the handset.
DIALING FREQUENTLY CALLED NUMBERS
1. Pick up the handset and press the mem button.
2. Press 0-9 for the memory location. The number dials automatically.
OR
1. Pick up the handset and press the dial button.
2. Press the review button for the desired memory location.
3. Press the dial button to dial the number.
OR
1. Press dial button while the handset is still in the cradle.
2. Press the review button for the desired memory location, lift the handset and the
Download User Manual
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Smcnas04 is down, how to take the files inside
We have this product but can not be used for requesting a serial number. and we lose the serial number. thanks for help
Harness on my stroller broke, they don't have a replacement available. any ideas where I may find one, my model number is 1070 serial number is 0517020380
replacement parts
LINK: http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11
Telephone
Graco Customer Service is available Monday through Friday, 8am to 5pm Eastern Time.
1-800-345-4109 (US)
Postal Address
Graco Children's Products Inc.
Attn: Graco Store Consumer Services
150 Oaklands Boulevard
Exton, PA 19341
8helpful
Audioline 20 Memory Speakerphone
1. Lift handset (releasing hook switch).or just press SPEAKER, ignore any noises or BT messages while you..
2. Press and release STORE key.
3. Press the keys for the telephone number
you wish to store.
4. Press and release the STORE key again.
5. Press the keypad number (0-9) you want
that telephone number stored in.
6. Your number is now stored.
Protron Address and/or Telephone Number
Address: 3257 E Guasti Rd Ste 320
Ontario, CA,
91761-1231
Phone: 909-354-4120
3helpful
ConairPhone SW324WCS
I just had same problem and went conairphone site and found model sw322 that looked about the same. I downloaded the manuel and it worked for my phone. Here it is. MEMORY FEATURE To Program Your CONAIRPHONETM telephone is equipped with 10 memories for programming your most frequently dialed telephone numbers. You can store up to 16 digits in each of the numeric keys (0 through 9), by following the steps outlined below: 1. Lift handset (releasing hook switch). 2. Press and release STORE key. 3. Press the keys for the telephone number you wish to store. 4. Press and release the STORE key again. 5. Press the keypad number (0-9) you want that telephone number stored in. 6. Your number is now stored. 7. To change a stored number, repeat the same process. The new number will store over the old stored number. A Memory Index card is provided for your use in writing down the person?s name. To Retrieve Memory Numbers Keypad Memories: To retrieve numbers stored in the keypad, pick up the handset and press the MEM (Memory) key. Then press the keypad number (0-9) which stores the telephone number you want to dial. Your call will be automatically dialed.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
