THIS USUALLY MEENS A STUCK KEY PAD OR CLOCK. SOMETIMES IF YOU UNPLUG IT FOR A WHILE IT WILL RESET. IF NOT IT NEEDS A TOUCKPAD
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Hi friend, thank you for your inquiry!
Based off your post your Frigidaire range is providing you an "E15" error code. "E15" stands for a signal loss between the oven relay and EOC (Electronic Oven Control) I would perform a reset on your appliance. You can do that by disconnecting power to your range by unplugging the power cord or flipping the household circuit breaker for roughly ten minutes.
If that does not correct the issue it could mean that your oven relay board or electronic oven control may need to be replaced. If that is the case I would suggest seeking assistance from a professional to avoid any unnecessary part purchases. -Matt
Good afternoon friend, thank you for your post!
I see you are having trouble with your Frigidaire range and you are receiving error code "Sd". However, it appears "Sd" is an invalid error code. It is possible that the error code is missing characters?
In the meantime, let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your dishwasher continues to display "Sd". I look forward to assisting you. -Matt
