Hi, in your case, it is almost impossible to remove the program using the common uninstall method, namely removing it through the Windows uninstall utility. It is suggested that you use a professional third-party uninstaller to forcibly uninstall the program. Just try using Perfect Uninstaller.
Click the download link here:
http://guides.mightyuninstaller.com/MU_Download.php
Def recommend revo uninstaller had the same problem wiht a couple programs
try to use revo uninstaller to uninstall a program.
Instructions to use the program :
open up a program and select the program you want to uninstall. Select the option safe uninstall and click next. It will start uninstalling a program. If it gives you any error you just need to click next and it will show you all the files from the registry, select the files highlited in bold and click delete then click next. press select all and then delete all. clcik next and then finish.
To download the software click on the link below :
http://download.cnet.com/Revo-Uninstaller/3000-2096_4-10687648.html
