Link for ya... might ahve to go into safe mode.... this should walk you through it
http://windows.microsoft.com/en-US/windows-vista/Startup-Repair-frequently-asked-questions
Peace,
Login With the Administrator Account in Windows XP Professional
Click
the "Start" menu and then click "Log Off."
Click
"Switch User" when the prompt screen opens.
Press
"Ctrl," "Alt" and "Delete."
Click
on "Administrator" when the "Log on to Windows" screen pops
up. Type in the administrator password, if applicable.
Click
"OK." You will now be logged in as the administrator.
Log On as An Administrator in Windows Vista
Start your computer and
allow it to continue through its startup process. By default your computer will
simply load directly to the primary user account (usually the administrator
account), but if there are multiple users on the system it will load to the
account login screen. Use the mouse to
click on the administrator account from the list of available accounts to log
on. This step is only necessary if you've customized Windows Vista with more
than one account or you have set the operating system to load the login screen
first. Enter the password
required in the password field to log on to the administrator account. Click the
"OK" or "Log On" button once you have entered the password.
This button may be labeled differently depending on the version of Windows Vista
or any GUI (graphical user interface) changes you may have made.
Log on as an administrator from within the Windows
Vista environment by clicking on "Start" and then "Log
Off." As soon as you have logged off, you will be returned to the login
screen where you can choose the administrator account from the available list.
If this answer helpful please vote me. Good luck. Thanks for using FixYa
1. Boot the computer in Safe mode( To Boot in safe mode you need to keep hitting the f8 keys while the computer Restart and you will prompt a screen which reads as Advanced boot Menu . in the windows please select safe mode with network ). An then try to login . and open misconfig and disable all the thrid party services and Restart the computer .
If you still have the problem boot the computer using vista Dvd . And select the option to startup repair option . That will fix the problem
