Question about Sony VAIO Digital Studio PCV-RX755 PC Desktop
Replace a new dvd burner into Sony Vaio desktop PCV-RX755(UC)
How to open the cover to Sony Vaio desktop PCV-RX755(UC); which cover (side or front). How to open the front facade to your PC before the old drive will slide out.), I try it before but failed.
Thanks you.
    Sergeant:
  • 233 Answers
Http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCVRX755&region_id=1.
this link will let you download users guide.all I could find .
Posted on Mar 06, 2010
6ya staff
SOURCE:
I have a Sony Vaio PCV-RX755 desktop computer and I think I need to replace the power supply. It shut down normally last night, but would not turn on this morning...no power at all. I checked all the...
I can just provide you the link where you can check the prices and the model itself. upgrading the power supply you can actually do that. specialy when you are not going to load hardware that has heavier power requirements then that's the time you need to upgrade the PS. Don't forget to get the model of the PS that you have. You can also visit any local computer shop. they can help you with this.
* http://product.pelltechnology.com/Sony_Vaio_PCVRX755_Power_Supply_Unit.asp
*http://www.impactcomputers.com/1-468-601-14.html
* http://www.sparepartswarehouse.com/Sony,Vaio,PCV-RX,Computer,Power-Supply.aspx
Mar 30, 2010 | Sony VAIO Digital Studio PCV-RX755...
How do I remove my DVD burner for replacement from my Sony VAIO PCV-RS720G? I get the two little screws out from the side, but then something hangs it up. Can't find what the hang up is. Thanks. Segalhund...
Segalhund, I appreciate your wanting a solution, but please refrain from stating your email addy.
There are three screws.
Facing the back of the computer.
One at the Top in the middle of the case cover.
One down on the Right side, straight across from where the monitor plugs into.
One down on the Left side straight across from where the monitor plugs into.
The cover is shaped like a hood, and slides towards the front of the computer.
I'm looking at the User Manual for the Sony Vaio PCV-RS720 Desktop PC right now.
This is Sony eSupport, and the download page for the Vaio PCVRS720G User Manual,
http://esupport.sony.com/US/perl/model-home.pl?mdl=PCV-RS720G&region_id=1
On this page left-click on Manuals, Specs, Warranty. (In blue to the upper right of the page)
On this page under the heading - Manuals -
left-click on - VAIO User Guide - in the list.
This is a PDF file. It may take as much as 30 seconds before you see the first page. Suggest you let it download all the way before looking through it.
Page 87 shows removing the cover.
Mar 28, 2010 | Sony VAIO PCV-RS720G (027242658103) PC...
I need to replace the DVD disk drive on my Sony VAIO PCV-RX580. I was able to remove the left side case cover but cannot figure out how to remove the other panels. Can you give me some assistance? Thanks -...
I also have a sony vaio but in replacing my drive I only had to remove the one side and two screws. Then push the drive from the front. the drive is "clipped" in there." It will come loose and just remove and replace. Good Luck
Mar 24, 2010 | Sony VAIO Digital Studio PCV-RX580 PC...
How to install a new dvd burner into the sony desktop pc PCV-RX755(UC)? How to take out the old DVD rom and put a new one in ? Thanks ...I don't know how to open the hard drive...
You don't want to open the hard drive. Just open the cover to your desktop PC; have a philips screwdriver handy, and then go in, unscrew or un-snap (depending on the situation). Carefully remove the ribbon cable and power connector. Your old drive should just slide out. (Note: You may have to remove the front facade to your PC before the old drive will slide out.)
Once the old one is out, just slide the new one in and reconnect power and data cables. Re-attach front facade if it was necessary to remove (I have a hunch it needed to come off), restart Windows. Your OS should let you know that it has detected a new device. From there, make sure you have Internet and then put in that you want to search the internet for a driver for the new drive. If one is not available, just use the one that came with a CD-ROM that you should have received with the new drive.
Hope this helps.
Feb 23, 2010 | Computers & Internet
How do you remove rh cover from Sony vaio PCV-RX755 desktop to replace a dvd drive
Download the System Reference Manual here:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCVRX755&LOC=3
See page 24.
1 Locate the tab on the upper right side of the rear panel, and pull it
back until the side panel releases.
2 Lift the side panel away from the unit and set aside.
Dec 31, 2009 | Sony Computers & Internet
I have a Sony Vaio desktop with XP. My DVD-CD
Have you tried burning a CD in the new drive? Because the drive is a DVD it will always be recognised as a DVD, but should work perfectly well with CDs both playing and recording.
Nov 07, 2009 | Sony VAIO Digital Studio PCV-RS220 PC...
Cant get cpu to see i have a 2.66 in there
More info about system and processor needed to fix. What's the processor's l2 cache? MOBO? BIOS version? The more info, the better the fix.
May 04, 2009 | Sony VAIO Digital Studio PCV-RX755...
Installing standard third-party optical drives in VAIO PCV-650 case
Hi there. I've worked for Sony VAIO and can assure you that the only solution is to get a Sony Branded Spare parts. The parts of Sony VAIO are very specific. As of now I see that the only solution for you is to either contact Sony Service Center or go for an external DVD Drive.
May 16, 2008 | Sony VAIO Digital Studio PCV-RX650 PC...
Sony PCV-RS720G - DVD-Rom gone bad
Here is a link to instructions that detail how to replace a hard drive but it shows you how to open the case: javascript:moreinfowindow('http://www.iq.sony.com/srvs/DocsConnect/docget.asp?manualid=90411&DL=',600,560,10,10,'Manuals')
Jul 26, 2007 | Sony VAIO PCV-RS720G (027242658103) PC...
Open Questions:
AOL MAil TelePHoNe NuMbER {1-855*536*5666}#O@ SUPPORT NUMBER call or contact SbCgLoBaL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL mAiL USA Calling SbCgLoBaL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL mAiL USA's phone numbers against each other. Contacting SbCgLoBaL mAiL USA in General WhileI:855:,:5365666 is SbCgLoBaL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL mAiL USA.call or contact AoL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL mAiL USA Calling AoL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL mAiL USA's phone numbers against each other. Contacting AoL mAiL USA in General WhileI:855:,:5365666 is AoL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL mAiL USA.
Nov 19, 2019 | AOL Computers & Internet
See all Sony VAIO Digital Studio PCV-RX755 PC Desktop Questions
Sony VAIO Digital Studio PCV-RX755 PC Desktop Logo
289 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
