All of the instructions can also be found at
www.SentrySafeShop.com
The link is:
http://www.sentrysafeshop.com//kb_results.asp?ID=7
Required Tools:
Drill, Wrench, 7/16" (11.0mm) bit, for wood anchoring: 9/32" (7.20mm) bit, for masonry
anchoring: 3/8" (9.5Omm) masonry drill bit.
The steps are as follows:
1. Tip the safe on its right side. (Door hinges horizontal with the floor)
2. Unlock the safe and open the door.
3. Look on the bottom (outside) of the safe for two indentations in opposite corners. Using a
7/16" (11.0mm) bit, drill a hole through each indentation perpendicular to the bottom of the
safe.
4. Close the door and tip the safe upright. Place it where desired and reopen the door.
5. Use a screw or drill bit to mark the floor through both holes.
6. Move the safe aside to clear both marked spots for drilling.
7. Drill into the floor:
a. For wood:
i. Using a 9/32" (7.2mm) bit drill a hole 2 Y2" (64mm) deep in each marked
spot.
b. For masonry:
i. Using a 3/8" (9.50 mm) bit drill a hole 2 Y2" (64mm) deep in each marked
spot.
ii. Install a masonry anchor in each hole.
8. Replace the safe in the desired position, with the holes in the safe aligned with those in
the floor.
9. Securing the safe:
a. For wood:
i. Pass each lag screw through a washer, then through the safe and into a hole. .
ii. Tighten with a wrench. ,
b. For masonry:
masonry anchor.
It's the shower wall I'm anchoring to, which I believe to be fiberglass.
I figured out the issue. Sterling screwed up in their manual print that came with the product. I went online and downloaded the install manual and it said drill 5/16. A couple other things were different, too, like how much I should cut off the bottom track measurement. Luckily the wrong manual said to take off less so if I run into a problem I can cut the excess off.
What substance are you putting the hole in? Is it drywall? If so, you should be fine. Just tap the anchor squarely and it should slide in. If it's tile you may want to use a rubber mallet so as not to chip the tile. The hole should be smaller than the anchor so that the anchor can grab onto the hole. Good luck!
