I've been able to play xbox live in the past with just my modem but then i got a new belkin F5D9230-4 router.Every time i can connect to xbox live but within diffrent times it'll either kick me out of games or kick me out of chat. i looked everywere for info and ive open the ports 88 udp, udp 3074 and tcp 3074. i even used the dmz and it didn't work. the connections fine and i have upnp enabled.is there anyhting else i can do?
The solution is as such, first log into your router by typing the routers IP (192.168.2.1) into your browser.
The first thing you want to do is set UPnP to be enabled.
Forget about the 88 UDP thing, it's bogus.
Just set the TCP and the UDP to 3074 in virtual server.
I swear to god it will work.
Sorry to know you are experiencing this issue - All you need to do is open ports, 53 ( TCP/UDP)and 3074 ( TCP/UDP) and then place the computer on DMZ. After placing the computer on DMZ enter the same ip address on XBOX manually - powercycle you xbox and will certainly work - still unable disable firewall on router
Guys I have been on the phone with support at belkin forever now... you will not get a solution they will eventually replace it thinking its faulty when in fact the fault is in the design... even if you go into setup and place the ip address in DMZ (which is another way of saying "outside of the NAT" you will still get errors when playing FFXI, xbox chat, video streaming, or any vpn connection) I had a linksys and didnt have any issues either.
by the way belkin's number is 800-223-5546 im bringing mine back to exchange it but maybe if enough people complain they will do something about the firmware
I think that the only way to have a good gaming experience is getting another router, not that expensive. It may work, but how wel does it work. The constant problems make gaming annoying and pointless. I used to use a lynksys router and absolutley no problems with xbox wireless hub.
i have the same prob
i need to get an open NAT
but it wont allow the router to work if the nat is open
I have the same problem. Can't Group up with others in XBOX Live.
I have the same problem.I had a another belkin router which broke so i got this one. Ive been trying to play games on live and i constantly get kicked out.
i have the same problem i had a lynksis that worked but got brok so i switched to this belkin and now i get kicked constantly eventhough my computers internet stays on.
same issues, xbox live, vpn, voice, video been on the phone with belkin they can't solve the issue. .... even if i manually enter the ports in virtual server or place the ip outside of the NAT by using DMZ ... still same problems
same exact problem i can play 1-3 games at the most than i get disconnected
same was wondering if it was due to my cable connection... but i dont think so now... it is
My son's xbox recently start showing the NAT at moderate and it started to kick him out, as well as not let him join with other guys on-line. I hope there is a quick pick.
