On the back of the TV is a label with a model number and chassis number (CTC....). What is the full chassis number?On the back of the TV is a label with a model number and chassis number (CTC....). What is the full chassis number?
You can't post conmments that contain an email address.
There is a little loose sleeve at the transformer. It can be pulled out, but it is best to squeeze the sides through hole on each side of the terminal to remove the sleeve. The wire just comes out with a small pull afetr the sleeve is removed. Good luck.
You can get one from Here http://www.partstore.com/Part/Thomson/RCA/237470/New.aspx
I would only use the original part. This site I gave you is for the original Horizontal output transistor. If the part goes bad again, or runs hot, the capacitors in the circuit or the flyback is bad. Good Luck
Heres the fix for your set, replace the following 2 parts:
1) flyback transformer RCA part number 257805
2) horizontal output transistor RCA part number 237470
you must be proficient at soldering & un-soldering or you can`t replace these yourself, be advised that the anode lead coming from the top of the flyback transformer can carry a VERY NASTY shock if not discharged properly before trying to remove it from the picture tube, I`d strongly advise you to call a tech unless your familiar with this type of repair, BMW Rider
If you can find the horizontal output transistor which is located near the flyback transformer,one lead of this drive transformer is connected to the base lead. (horizontal output transistor). There may be a little coil in series with this lead going to the transistor.
