I have a Magnavox Am/FM/Stero phono with open reel tape deck but recently I find that my radio doesn't work on AM. It's an old set, I know, but I would like to find a repair person or firm that can fix this. The console has transistors-no vacuum tubes.
Does FM work? If so, I would expect AM to work also. Old AM circuits are pretty resilient. If you rotate the tuning dial in AM mode, can you hear distinct changes in the sound (noise) coming from the speaker(s)? I'm thinking there's no wire attached to the AM antenna on the back. Without the antenna, you might not get any audio output.
You do need an amp of some kind. On the back of the deck will be RCA sockets, in the red and white ones you plug a line cable to the audio in sockets of an amp or receiver. The other two sockets are record. They go to the audio out of the amp.
You need new brake pads installed as the ones in there now are dried up and may have fallen off. This is very common with older decks or 30-40 years old. I am still working on these decks at Skywave Tape Deck Repair in the Chicago area.
Well two things have to happen to make tape move in a cassette deck. One is the Capstan shaft has to rotate and that is usually a belt link to a motor through a pulley. The second thing is you must have take-up torque. If the tape moves but the take-up reel does not pull it onto the take-up reel then you either have a eaten tape or the deck will shut off. in your complaint it could be any of these items- maybe a bad Idler from the reel motor or the capstan belt is old and stretched.
For a turntable - apparently, yes - a phono preamp. Tape decks don't require anything special analog-connection-wise. What product are we talking about?
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
If your unit doesn't have a PHONO connection AND your TT doesn't have a self-contained preamp you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
A stereo or amp, either one should have a fuse, fuses for radios would be in the wiring harness behind the radio deck. An amp fuse should be obvious were they insert in the fuse blocks by the amps main power cable connector. If you see that all fuses are fine then check your ground wires if not then your radio is bad.
Grundig TK23
Inputs at rear of machine. From Left to right.
Circle with line underneath. (Micro socket) - microphone, mixer (Grundig 607), telephone adapter.
Square with line on top - Radio input/Output. Record/playback radio. Record records if player is connected to radio for playback via a 3-pole amplifier unit. Re-recording to a second tape recorder. Connection to a Grundig Stereo-Mixer 608.
Reversed Q - Phono Input. Connection to a record player or a second tape recorder. (for re-recording records or tapes)
Squiggly lines - Outputs. - Connection to external speakers. Grundig Stereo Box. Connection to an additional amplifier (Grundig 229) for synchronous recording.
Square with line at right. - Earphones.
Loudspeaker switch - (At bottom) - In the "0" position, the internal speakers are shut off.
There is a surprising interest in "vintage" hifi products these days. Your tape machines probably needs new belts. Check this site out. You can get spares for your tape machine here. Belt kits are $17. He does repairs also, but the transport to and from may be an issue for you. I suggest emailing Bob, he may be able to refer you to someone in CA > I could do the repairs,but I am in Australia. :)
