The outside screen shows nothing but the motorola logo. I have tried to set a photo and it works on the inside display but not the outside. Caller ID does not show--nothing but the logo on the outside. Help.
take out batt hold * & # place batt on and power up once logo comes up release * n # and it will take u to service screen then follow command or just turn off
Depending on how many modifications, hacks, or customizations that you perform on your Motorola RAZR V3 phone, there may be situations where the phone becomes unusable or completely locks up. I have had visitors to the site report not being able to delete ring tones, text messages, or have other strange behaviors with their Motorola RAZR V3 phone.
If this is you situation, then you may be interested in performing a master reset (or “hard reset”) on your phone. The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3: 1. Open your phone up and go to “Settings” 2. Next go to the selection for “Initial Setup” 3. Next go to the selection for “Master Clear” 4. Then select to confirm the option. 5. Now enter the security code which should be “000000” 6. Finally press select or ok and the phone will reset itself to the factory condition
Congratulation you have performed a “hard reset”, “hard reboot”, or “master reset” on your Motorola V3 RAZR and it should return to normal operating mode!
Trackbacks that led to this post: hard reset motorolla razr v3 hard reset razr phone wii master reset hard reboot motorazr how to hard reset a razor v3 master reset code for motorola v3 master reset code razr v3 master reset for v3 via pc master reset motorola razr 2 master reset v3 razr with white screen motorola v3m master reset p2k commander razor master reset razr 3 and how to reset razr master reset ebay razr master reset password razr master restart razr screen master reset reset razr reset razr to factory reset razr v3 to factory v3 hard reset razr v3 razr reset hard boot
I had the same problem. I sent it back to Motorola for warranty. They fixed it and said it was a connection issue.The connection between the screen and the keys came unplugged. This is a regular problem they have with this phone. The phone is poor quality!!!!
Does anything show on the external display if you go to take a picture, but before you acually take it, close the phone and look on the external display as if you were taking a self-portrait?
To make fully sure, while the phone is closed, press a volume button - does anything show on the display? If so, the external display functions and it would be a setting that may have been overlooked.
Go to Menu > Settings > Initial Setup > Display Timeout
or:
Menu > Settings > Personalise > Home Screen
I'm having the same trouble, and I've found it's because the v3 no longer recognizes the opening and closing of the phone itself. You see, when you close it, something is triggered that tells the phone to shut off the main screen and change the outer screen to the usual mode where it shows the time. You can also test this by trying to take a picture and closing the phone - the external lcd no longer doubles as a second camera display to easily take pictures of yourself.
I dropped mine into the toilet, and I'm not sure if there's anything to do but take it to a tech. Sounds and looks like a hardware problem to me.
Only the T-Mobile logo will show, can't get Caller ID to display.
