Dishwashers Logo
Posted on Mar 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not washing dishes - Dishwashers
Anonymous
Level 2:
  • Expert 457 Answers
  • Posted on Mar 06, 2010
Anonymous
Expert
Level 2:
Answers
457
Questions
Helped
126639
Points
799
Check the water make sure the water is correct. fill water drain water and circulation water.
fill water comes from under sink, drain water from drain pump and drain hose ,circulation pump controls the water washing. let me know if this helps.
Why are dishes clean but still seem to be greasy?
hi,you can take off the washers that spin and clean them ( sometimes the holes get blocked on them ) also make sure you have salt in the machine and rinse aid
Apr 24, 2015 • Dishwashers
Washed bsking dishes in dishwasher j had hotshot iin disher when i did wash of fishes we baked snd ate off dshes can we get sick?
If you are in any doubt about the ability to properly clean your dishes etc, then get an engineer to check it out.
You could always wash the dishes yourself?
Jul 21, 2014 • Dishwashers
1helpful
2answers
What is the best way to wash dishes when camping?
I found this greatsite that will help you when it comes to camping and washing your dirty disesand laundry ect http://www.your-camping-guidebook.com/camping-dishwashing.html
2answers
The water does not get hot enough. I think it's the reason why dishes are not coming out clean. In normal conditions do I need to wash the dishes (like the manager of this apt. complex suggests) before I...
No you need not wash the dishes but just cleaning of the debris and then putting it in the dishwasher for proper cleaning will help you to prevent the drain from getting blocked.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
When we open dishwasher theres standing water in the drain area and it smells bad this is after washing aload dishs look clean but inside stinks
After you run a load of dishes put 1cup of CLR or vinegar (white) and run a quick wash.no dishes,after running dishes clean out spray arm and clean strainer,use a rinse agent like finish, and spray off dishes before loading.About 35yrs. ago I use to be a dishwasher as one of my first job's and if you did'nt spray the dishes and scrap them off before loading,the dishes would not come out clean,And after each shift the dish washer would be cleaned out.
Doesn't seem to wash the dishes. Maybe the wash
make sure the sprayarms are free from food deposits
and also spraying off food from dishes may help out check hot-water is on and heating element is working
Nov 25, 2009 • Dishwashers
After wash cycle and rinsed cycle there were suds
Make certain you do not use dish soap when rinsing the dishes. Make sure you only use DISHWASHER soap when running the DW.
In fact,there is no need to rinse dishes. Remove visible scraps and put them in the DW. If it is a quality DW it will clean your dishes. Do not crowd the dishes in the DW. Most JennAir DW's are quality. Make sure the top rack can get washing action from the bottom spray arm. No pots or other water stopping utensils on the bottom rack.
Mold growing on dishes
Recommend that you run another cycle with no DW soap aded, waiting until the dishwasher has filled with hot water and begins to do the first wash cycle. Then add 1/2 cup of bleach to the water and close the door. Allow the cycle to finish. Run it normally with a standard load of dirty dishes. Note: These high efficiency dishwashers count on the "dirt" of the dirty dishes to help wash/clean the dishes. Recommend you not rinse/wash the dishes before you put them in the dishwasher.
Watch for any occurrence of the black dots and repeat the bleach treatment.
Model # dwu7702aae has heat delay light coming on during cycle. Why?
Heater is used to both heat water during clean cycle and dry dishes after wash cycle. Most washers have either a separate switch for Heat or Dry for optional use, or some have the water heat and dish dry options built into cycle set options.
You can save money by turning off the Dish Dry option since it is a very in-efficient way to dry dishes. Instead, open the wishwasher door after washing cycle completes, just enough so fresh air can get into, and humid air can escape, dishwasher.
Water Heat option is only needed for dried food on dishes, and is never needed if dishes are either rised off before putting them in the dishwasher, or rinsed off inside the dishwaser with a Rinse cycle, if they are to stand for a time waiting for a full dishwasher for wash.
4helpful
4answers
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
