Toshiba mini NB205-N312/BL Notebook Logo
Posted on Mar 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My cursor froze.
I'm not sure if I pressed a series of buttons or not but my arrow will not move. Everything else is fine. I have several term papers due and I need to be able to mbr my cursor
Anonymous
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Mar 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
6956
Points
49
Anonymous
Level 2:
Sergeant:
  • Expert 212 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
212
Questions
0
Helped
71264
Points
660
This is a software or possibly a touch pad mouse issue. First you can quickly correct this by going to accessories located under start in Vista and going to system recovery. Tell it in that section to revert to an earlier time. Remember when the mouse was working? What date? click on the date when the mouse was working and click next.
The computer will reboot and mouse should be working. If not the mouse touch pad may need to be replaced. Buy a usb mouse for now if you have to work on it immediatly.
On my new asus laptop I cant use the touchpad to do anything. It seems to have locked. The cursor is on screen but doesnt move.
Sometimes there's a mouse pic on one of your function keys to local/unlock pad. Hold the function key while tapping the f key once to unlock
My cursor froze and it wont't move
Try to force your machine to power down (off) by pressing and holding the power button for several seconds (up to 10). If no success, disconnect any AC power and remove the battery. {It can not run without a source of power.} After it has powered down, do what is necessary to restart it. The problem should be gone for the moment. If you had to remove the battery to get the machine to turn off, go into your operating system options and configure the power button to "shut down" a running machine when it is pressed and held down.
Fx-82ES How to use the replay button?
After you execute a command (=) and have the result displayed, you can press the Left Arrow of the Replay button to move the cursor to the end of the last command line.Use Left arrow/Right arrow to move cursor along the line and modify it (change a value, operation sign, etc.) After you make the changes press the = sign to execute the modified command.
4helpful
2answers
Dell wireless mouse cursor froze in middle of screen.
Hi, my cursor had frozen on my screen after my grand daughter pressing something. After trying everything I decided to take it to a local computer shop, it was fixed in seconds. He held the arrow tab(below the caps lock tab) and then pressed F9 it worked!!
Hope this will fix your problem
1helpful
Cursor on Compaq Notebook not moving after complete start up.
while playing game your son must have pressed the mouse lock button try to check it out and please be sure u have unlocked it
1helpful
Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn / 3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn / 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Size appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or MPF) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper size, as shown in Figure 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure 1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the MPF only.
Verify the printing preferences on the Dell™ 3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with the correct paper size, perform the following steps:
  1. Click the Start button, go to Settings, and click Printers and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser Printer 3000cn / 3010cn / 3100cn / 5100cn-series and click Printing Preferences.
    The Printing Preferences window appears.
  3. Verify the Paper Size drop-down is set to the correct paper size loaded in the specific tray to be printed from..
  4. Click the Paper Tray tab.
  5. Click the Paper Source drop-down menu and select the specific tray to be printed from.
    This sets the size and tray defaults.
Verify the Paper Size From the Printing Application Matches the Designated Printer Tray
To verify the paper size from the printing application matches the designated printer tray, perform the following steps:
  1. Open the application being used to print the document. (Example: Microsoft Word)
  2. Click File and click Print.
  3. Verify the paper size.
Verify the Paper Source From the Printing Application Matches the Designated Printer Tray
  3. Verify the paper source.
Do not replace any printer hardware as this is not a printer hardware issue.
Won't take paper
Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary and no more than three (3) times.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for additional information.
  3. Press the <Menu> button.
  4. Use the right / left cursor button to select [Maintenance/settings] press the <OK> button.
    Note: This procedure is skipped if your machine is in Scan mode. Proceed to step 5.
  5. Use the right / left cursor button to select [Maintenance] and the press the <OK> button.
  6. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
  7. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2, and press the <Open> button.
  9. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
  10. Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
    Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
ASF
Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Source setting in the printer driver. If the option is not set to 'Paper Feed Switch', paper will feed from the source selected in the driver.
Click to return to step 2 above.
1helpful
2answers
Up arrow key sticks
This fix also works for the LX 710 Cordless! Yay! Thank you.
2answers
How can I change the Resolution?
Olympus has its own way of showing the resolution settings. It is OK once you get used to it. Turn the Camera On. (On the back you will see an OK button surrounded by 4 arrows.) Press the OK button to bring up the menu. Press the left arrow button That should bring up a choice of: TIFF, SHQ, HQ, SQ1, SQ2 Use the up/down arrow buttons to move the cursor to SQ1 Then press the right arrow button That should bring up a choice of settings. Use the up/down buttons to select a setting. I suggest you select 2048x1536 (which is 3 megapixels) Then press the OK button. ................ You should think about getting a memory card with a greater capacity.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
