I have a Miele W916 front-loading washing machine which fills slowly. I thought it might have been the electronic valve in the waterproof inlet hose, so installed another hose - but same problem! Any ideas what else to look for?
Hi
There are two variant of this model one with normal fill hose and triple valve and one with waterproof system and triple valve. If you have change water proof hose (one with grey box on end) then it only leaves the triple valve.if waterproof hose is fitted be sure to order 110volt triple valve
We had the same problem with W1966, but we solved it differently. The problem was the cold water valve for the main wash and rinse. Since we do not use fabric softener, I swaped the two valves hoses and electric connection. Swapped terminal 3 and 4. This part is very hard to find, because it a 240VAC type, in the USA. Any one know where to find it?
Peter Sikstrom
both red lights flashing plus delay start orange flashing, what does this mean
