Master
- Posted on Mar 05, 2010
Re: Where would i find the static ip adress
Static Ips are the ones that you yourself will define in your every computer in your network. Also, you need to configure your router to use static IP. So, 2 things to remember.
Setting your router for Static IP.
- Open your router web interface at http://192.168.1.1 or http://192.168.0.1 (depending on your router model)
- Disable the DHCP server by un-checking this DHCP option.
- Save your changed settings.
Configuring Static IP of computers.(This applies to MS Windows XP only)
- Click Start => Settings => Network Connections
- Right click on your LAN Connection and click "Properties".
- On the General Tab, scroll down to TCP/IP, Click on it to select and click the "Properties" button.
- Make sure that you ticked the option button: "Use the following IP Address" and you need to define the IP.
