Get the HARD-DISK completely reformatted by the service center.then check out.most probably the space is got completed so its showing Capacity Used Available 0.000GB 0.000GB .so reformatting will clean out if any of the error is got occurred in the hard disk.or the other possibility is the hardware problem.the problem in the main circuit board of the unit.its got hanged on stand-by mode.but changing the version should help if its got hanged on stand-by mode.but nothing changed that means the board is got corrupted in the unit.either the board or the unit needs replacement.
then check out.keep updated.thanks.
2. A radio service tried to put in a new hard drive -> no change -> old disk replaced.
A new hard-disk was put in the Radio - same behavior !! - so I put the old disk in again.
and how do I format the system ?
The problem is:
I have a Grand Cherokee Ltd '08 and a Sirius REN radio. Suddenly on all music/pictures was unavailable. Radio and CD works fine but I cannot communicate in any way to the hard-drive. If I put in USB key - it blinks but no data or connectivity to hard disk.
If I look up my data it shows:
0.000GB 0.000GB
Application version 8.400
Grace notes N/A (init)
Serial T00BE219709598
System 6825 006 3.3
What I have done trying to fix this is:
1. Unplugged the battery from the car -> no change
2. A radio service put in a new hard drive -> no change -> old disk replaced
3. My local JEEP dealer connected the car with their computer -> no error codes from the radio
4. Unplugged IOD fuse - > no change
5. Tried to update to version 9.113 and 9.292 -> installed normally -> rebooted -> no change.
