Question about Akai LCT2060 Television
Tv has sparks light on picture
What can I do
Run
Posted on Sep 27, 2008
6ya staff
SOURCE:
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
I have a LG CRT TV This tv tly back HOLDER HV cable sparking its very big spark - bulb HV cable connector ...not showing picture .show spark lighting ... how can fix this? what parts of trouble ?
Replace the FBT. Never switch on this set, any more; till it has been replaced. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to get gathered related posts.
Sep 29, 2015 | LG Televison & Video
My toshiba tv wont turn on
FIRST GREEN LIGHT WOULD COME ON. TOOK IT AWHILE BUT ITWOULD FINALLY TURN ON...NO NOTHING. IT'S GETTING SPARK CAUSE WHEN I PLUG AND UNPLUG IT AT THE SOURCE OF ENERGY IT SPARKS. FUSE IS NOT BLOWN
Feb 13, 2012 | RCA F27450 27" TV
When I turn it on, it makes a buzzy noise but nothing else., no picture or tv sound.
The set has a high voltage problem, "the flyack transformer is defective" It generates the high voltage in the picture tube and with the help of the video circuits it produces a picture. It is not cost effective to repair the tv, cheaper to replace.
Jan 30, 2011 | RCA 27V530T 27" TV
The tv is having a cracking sound and there is spark inside. the tv is having picture problems everytime it is turned on.
There is leakage of high voltage from LOT (line output transformer) causing sparking,get this LOT replaced and do not turn the set ON as it may damage the complete set,one of the other cause of sparking is picture tube earthing is not proper,call some technical expert to rectify,memory loss is also due to this sparking.
Jan 25, 2011 | JVC AV-24F702 24" TV
When I turn on the tv, it makes a sparkly sound and shuts off.
You probably have a high voltage failure causing the TV to sense the overload and shut off. There is about 30,000 volt required to light your picture tube focus the picture. If there is a failure anywhere in this circuit you will get the hissing noise and occasionally an ozone smell. I recommend you contact a TV serviceman to diagnose and repair this problem.
Oct 08, 2009 | RCA D52W23 52" HDTV CRT TV
HitachI HD DIGITAL TV 53"
Good Day;
For dark picture check RP41 heater circuit, 1.5 ohm, may have changed value & clean spark gaps. Good Luck, big IRISH.
Sep 04, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Sony kp-61v35
Unless you can do tv repair your set has more wrong with it then something minor,it more then likely has a shorted Hori out put transistor NTE2973 and maybe open pico fuses.Take set to repair shop. ThankYou for using FixYa. Have a Nice Day.
Feb 08, 2008 | Televison & Video
Akai LCT2060 Television Logo
15 people viewed this question
Top Akai Televison & Video Experts
KISHORE DESHPANDE
Ekse
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
