The dryer was working. I opened the door to check on the clothes. Upon closing the dryer, I turned the knob and pushed it ot start. However it did not start. I could hear a ticking sound like the timer was tiking but it would not start. It apear the door switch is not broken. I am thinking it is in the main dryer switch or the heat coil or fuse. I am leaning to the main dryer swith as the problem. Can I test the swith with an ohm meter tester? How hard is it to replace the switch?
There
can be many reasons why your dryer will not start or turn...
The
most common causes are the belt breaking or jumping off, or the motor
going bad...
Here are a couple of tips that I wrote will help
you to figure out why your dryer will not run...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
