Question about Nixon Rotolog Leather Watch
I have the same problem with mine-- light works but time is stuck - what is wrong? does the watch have two separate batteries?
  • Anonymous Mar 28, 2010
    The rotolog watches have three batteries actually. Two for the ledlight and one for the clock mechanism. This battery will last about two years till it needs changing.
    New Friend:
No problem, but charger should be common
Posted on Mar 04, 2010
6ya staff
SOURCE:
Flashing time display
Nike Triax Fury 100 Super
You need to replace the battery. I had the same problem. Replaced the battery on mine and everything is fine now.
Sep 08, 2012 | Nike Wr0139001 Triax Fury 100 Regular...
What kind of battery does the texas instruments model 101 watch use?
I am pretty certain that this watch uses two #386 silver oxide button cells. Alkaline cells would work, too, but they'd burn out more quickly--not that batteries last all that long in this watch, anyway. I'm basing this on the slightly newer (~1976-78) plastic-bodied TI LED watch that I have in front of me that I believe contains the same time keeping module as the original model 101.
It is also possible that the earlier watch would have taken #357 batteries, which are the same diameter as #386 cells but slightly taller. Both battery types were popular in LED watches of the time. However, I would suggest starting with #386 cells, as I destroyed the case back of a plastic TI LED watch many years ago by trying to use #357 batteries instead of the slightly smaller 386s. Both batteries put out the same voltage, so the watch will light up with either. However, the case back won't close if the battery is too tall--and if you force it, you can bend, distort, or shatter (in my case) the all-but-unobtainable case back.
Have fun with this watch! Mine still lights up and keeps good time.
May 28, 2011 | Watches
I own a Citizen Eco Drive Calibre 8700 Blue dial Romen letters. I have not used it for very long time (6 months). Now when exposed to light only the second hand works but the minute hand and hour hand do...
If your watch was not stored where it could have light shining on it the LI battery would drain completely. There is a possible solution although it does not work all the time. It depends on how badly the battery has been allowed to drain.
Setup a lamp that will shine on a counter 24 hours a day and set your watch there. It helps if the lamp is about 1.5 - 2 feet above the watch. A 60 watt incand. lamp will work fine.
Leave your watch under this lamp for 3 - 4 days 24 hours a day. This will supply the solar cells with enough energy to recharge the battery and get it working again. If after this time it is still not working then the battery is just not going to accept a charge again or there is something else wrong that a watchmaker is going to have to fix for you.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 02, 2009 | Citizen Eco-Drive Calibre 8700 Wrist Watch
After about two years, my indiglo night light function stopped working. The watch is still working, keeping time. Will changing the battery fix the indiglo problem?
Definitely, battery change will solve the Indiglo light problem. Many of wristwatches has separate battery for Indiglo function, but my advise is to change them both at once - will be cheaper for you.
Rate me, please.
Sep 01, 2009 | Timex 2J611 Watch
Had new battery now watch 4 hours behind CASIO WAVE CEPTER
It sounds like your in the wrong time zone and day light saving is in the wrong mode.
Sep 06, 2008 | Casio Wave Ceptor Atomic Silver Tone with...
I have a Timex Ironman 53151 watch but there is no sound. The light and everything else works except the sound. What is wrong with it?
got a new battery in ironman and the beep will not sound when i press the start and end button on while in stopwatch mode
Apr 19, 2008 | Timex Ironman 53151 Wrist Watch
Casio G-Shock GW-300 2608
Change the battery. This happened with mine along with the battery needing charging more frequently. In my opinion, Casio's assertions that you won't need to change the battery is pretty much of a joke. My jewler concurred.
After changing the battery I can now press the light switch button and the watch works normally.
Tony
Feb 25, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
CASIO PAG-40 Keeps good time but buttons stopped working
open the backside.
probably the light switch contact at the six side of the watch (attached to the steel mainframe) may have contact with the electronic cirquit
Jan 13, 2008 | Casio PRG-40T-7 Pathfinder
Setting the time on a Timex Data Link 851 Watch
You have to use the USB cable and do it through your computer. There is no way to change the time on the watch. Bad design.
Dec 31, 2007 | Watches
Watch stops
i have no solution but i cant even get mine open, how do i open this? rich@potterandco.com
Nov 01, 2007 | Watches
Nixon Rotolog Leather Watch Logo
462 people viewed this question
Top Nixon Watches Experts
Janelle Schoonover
Janelle Schoonover
rhodesworks
ray gallant
ray gallant
Are you a Nixon Watch Expert? Answer questions, earn points and help others
