Question about Acer 22" X223w LCD Monitor
Power button blinking on and off. Not powering up. Acer x223w lcd monitor.
  • 107 Answers
It means your monitor doesn't receive any signal from the system unit, have you check its connection? or RAM, or your video card? try to clean your RAM with a pencil eraser like wise with your Vcard, maybe one of them is busted. Now replace it
Posted on Mar 05, 2010
6ya staff
SOURCE:
How can I fix Acer X223W Monitor blinking?
You need to replace 5 Electrolytic capacitors on the Power Board.
Cheers
May 20, 2014 | Acer X223W Monitor
Acer monitor will not start, power button flashes
hi Samuel.
this is all i could find from the internet.
You can try a power reset to see if that helps. To do a power reset, unplug the power cable and press and hold the power key for 10 seconds. Then, release the power key and plug the monitor in and attempt to use it. If you are still unable to get a proper display, We would suggest contacting technical support to inquire about warranty repair options. Many of our monitors carry a 3 year warranty, so there is a chance you may still have warranty left.
Acer Service and Support
you could also try this link out.
Acer 22 X223w LCD Monitor will not start up Google Search
Dec 14, 2017 | Acer 22" X223w LCD Monitor
I have a x223w no sound
Spec of X223W: http://reviews.cnet.com/lcd-monitors/acer-x223wbd-lcd-display/4507-3174_7-32908354.html?tag=mncolBtm;rnav
As you can see, the monitor does not have built-in speakers. Please verify the make and model.
Apr 08, 2010 | Acer AL1917W LCD Monitor
How do I get sound from the Acer LCD monitor?
connect stereo audio cable from monitor to pc audio output
Mar 27, 2010 | Acer 22" X223w LCD Monitor
Monitor won't come out of sleep mode, computer was still running.
Press the power button on the computer to bring the computer out of hibernation.
Aug 08, 2009 | Acer 22" X223w LCD Monitor
I can't open the user guide off the disc for my X223W LCD acer Monitor
Ah.
Is there any error message?
Should be an PDF file. Is Adobe Acrobat Reader installed or any alternative PDF Reader?
Download User Manual Acer X223W (zip file)
Jun 11, 2009 | Acer 22" X223w LCD Monitor
Acer x223w monitor
Hi..there,
If you wanted to be crystal clear... Try using a DVI cable if your monitor got these function. Happy Holidays!
Dec 18, 2008 | Acer 22" X223w LCD Monitor
New install Acer x223w monitor
You would only need that cable if the other end requires a VGA end. Happy Holidays
Dec 17, 2008 | Acer 22" X223w LCD Monitor
Open Questions:
Display not working, power button LED turns on blue for 1 second and won't turn on again I've searched the web as well as this site and can't find my exact issue anywhere. I hope I'm not duplicating this question though. My X223W monitor is pushing 6 years old. It was working perfectly 4 weeks ago before a 1 week trip. When I returned, I pressed the power button to turn it on. The power buttom LED simply turned on blue and then turned off after 1 second. I get NOTHING on the display itself, not even a flicker nor the Acer logo. Pressing the power button again got nothing - not even the 1-second power button light. I unplugged the monitor, plugged it into a wall outlet it was plugged into a power strip the whole week I was gone, tried the power button again, but got NOTHING. Not even the 1 second power button LED. Here is what I have tried to fix this: 1. Tried 3 different power cables that are confirmed working - nothing. 2. Tried 2 different outlets that are also confirmed working - nothing. 3. Tried unplugging the monitor, holding the power button for 10 seconds to do a reset - nothing. Although, this did accomplish restarting the cycle in which I am able to get the power button LED to do its 1 second turn on/off again. Still nothing on the display, though. 4. Took apart the monitor to look at the power supply board capacitors. None of them were blown, bulging, or looking strange at all, but I ordered a kit online to replace them anyway. When done, I triple checked my solder points, cap orientation, uF size of each cap, and re-connection of all cables - all good. But, the symptom is exactly the same. Same 1 second power button LED turning on/off with nothing on the display. Because of the age of the monitor, I think I'll likely just buy a new Acer. But, I'd love to fix this one eventually so that I could maybe end up with two displays. Is there another component I should be looking at that might cause this? Should I replace the entire power board? Is in an inverter? The logic board perhaps? Any advice would be welcome.
Jun 12, 2016 | Acer 22" X223w LCD Monitor
See all Acer 22" X223w LCD Monitor Questions
Acer 22" X223w LCD Monitor Logo
338 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
