Picture images getting dimmer or fading like no backlights
When turn on power for a moment, then picture shows up very
slow, then getting dimmer.I noted there isn't any backlights, and then picture images getting dimmer/fading slowly, very hard to see. I tried to adjust brightness, but no help. Is there any experts can help me please.
Thanks
picture goes black or dims to black .....turn power off and back on...picture returns but may stay or fade again...have in past resoldered most of board but beleive this problem is in triac? do these sets use one on remote control power? this problem occurred quite a while after the resolder cured the previous prob. where can i get a schem? this is an older trinitron pre wega?
Re: picture images getting dimmer or fading like no...
Hiii...
I'm not quietly sure ...have you check the GK Board looks at B+(135 V) check all 5V regulated..check all High voltage capacitor if there's have low ESR or dry cap...
# send me an e-mail to : [email protected] for compplete copy of the schematic...
That is the right amount of voltage the issue is when one or more of the individual LED lights fail, the current changes and the power supply senses it and shuts down.
You likely have a LCD set there which may likely use a back light inside to light the image, get the room as dark as you can and with a flashlight illuminate the screen from a angle, with set on if you can see the faint image on the screen of the program you have a Backlight issue'
1. Voltage not there or not being switched on for backlight.
2. Actual back light bad.
If the image can be seen with a flashlight one of the above is the issue and your "picture will appear very faintly" also suggests this.
It's a backlight or backlight inverter issue. (The backlight itself usually fades or makes the on-screen image change to pink/red.) For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.)
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight.
This could be the backlight failing (most often the images will tend to go pink). If the TV is out of warranty, you can replace the backlight(s) yourself. lcdparts.net has many backlights but you need to match the length and width to the original. Next you need to open up the back of the TV and carefully remove the old backlight(s). The backlights are on the perimeter of the TV (laptop screens started with one but most TVs have several to maintain an even lighting of the image).) The removal takes some work and paying attention to how the original is put together. The backlights are often molded into the frame of the TV and a Dremel or other rotary tool is needed to get the backlight out. Google backlight replacement for videos, pictures and descriptions of the process.
Hi! When a monitor display image for a second and then goes to black screen... there are possible reasons why this problem
occur..
1. You need to check if the high voltage ballast
transformer of your backlight inverter is about to be burned... the
transformer is overheating..that's why you experience the monitor
working for a couple of seconds and then it will shut off until the
transformer cool down again and then it will be ready to work again...
2. Check also the backlight inverter if it is busted...the backlight inverter is the light source responsible for the image display you seen on your screen. If this are busted then all that you will be seeing is black screen
3.
You need to check the power supply section for possible loose
connections and possible blown and bad capacitors..
the ballast transformer has direct
effect on power supply section.. when there is overheating
transformer,,, the supply current from the power supply section becomes
unstable.. and will not be able to supply the remaining good working
ballast transformer.
In case you do not know, the ballast
transformer generates high voltage for the backlight inverter to
work....
Please be advise that if
you don't have the knowledge, the proper skills and the right tools to
open the back cover of your monitor and replace its part...don't risk
it...
Otherwise, bring your unit to a credible technician and avail of warranty if there is any.....
Much appreciated if you rate this help...thanks...
There are 4 c5707/5706 in the inverter transformer driving circuits, the cause of the problem was due to poor solder connection in the bias circuits of the transistors. Make sure to check that after you install the new transistors otherwise you will blowthem up. Common problem with this model. When the circuit drwas too much power from the power supply, it will shut itself off to ptotect itself.
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp. Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net
