If camera show Memory Card Error, Check whether the card is inserted properly or not. For SD card, check out the card lock switch is in the correct position and not stuck in between.
You can Format the memory card in the camera using the Setup Menu option (Format). Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data.
If after formatting the card do not clear the error, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Rating the solution is highly appriciated...Good Luck
