Question about Samsung SMH7174BC Microwave Oven
Samsung overcounter microwave-light and fan problem
Both over-the-counter lights will not turn on. Bulbs have both been replaced but no change in status. Also, the fan has three settings (low, high, turbo) but only works on the turbo setting. We think both problems started at the same time.
  • Samsung Master
  • 9,179 Answers
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 04, 2008
  • Himarx Aug 14, 2014
    you're link isn't working for me..
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
Need to replace both might lights under microwave.
Remove the screw from the lens cover and open lens. Turn light bulb counter clockwise and remove. Repeat this on other side. The bulbs or 40W appliance bulbs. Take the old one with you to hardware store to match it up. Reverse your steps to put new ones in.
Jun 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Bulbs UNDER the microwave burned out; new bulbs don't work
i know this is going to make no sense . but in my samsung service cd it is in BOLD PRINT YOU MUST DISCONECT POWER BEFORE REPLACEING BULBS , OR DAMAGE TO TIMER WILL RESULT ! the first time you changed them did you disconect power ? if not , your board might be toast , $$$$$$$$$
Jan 24, 2009 | Samsung SMH7174BC Microwave Oven
Samsung SMH7178STD microwave fan stopped working
It looks like the part of your computer board on microwave which responsible for controlling light and fan stop working. In this case you have to replace computer board.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 03, 2008 | Samsung SMH7178STD Microwave Oven
JENN Air bulb replacement problems
We see (and repair) this a lot. The problem is indeed on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 08, 2008 | GE JVM1850 1000 Watts Microwave Oven
GE JVM192K over-the-range microwave counter lights off
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
Sep 13, 2008 | GE JVM1650 1000 Watts Microwave Oven
Counter Top Lights do not work
Mar 18, 2008 | Microwave Ovens
Samsung Microwave problems
Dec 26, 2007 | Microwave Ovens
After changing a blown oven light, the clock works but nothing else turns on, including the fan, light, microwave
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
Nov 27, 2007 | Whirlpool MH7135XE Microwave Oven
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
432 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Ekse
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
