Samsung B1245 Front Load Washer Logo
Posted on Mar 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung 1215j front loader when it reaches rinsing and spinning makes noise but doesn't rinse or spin. but if it without load it performs well
Gerry Harvey
Level 3:
Genius:
  • Samsung Master 1,482 Answers
  • Posted on Mar 03, 2010
Gerry Harvey
Samsung Master
Level 3:
Genius:
Answers
1482
Questions
0
Helped
378767
Points
4533
Check pumping ok if not clean filter
Why is it that my LG machine shakes violently while it's rinsing? Is it supposed to be like that please?
Question 2 also edited for clarity, 'LG' not 'lg'.
No model details again.
Surely not during 'Rinse' cycle? That just adds water and gently tumbles to get the soap out and complete the washing by further agitating the clothes. You must mean during spinning and much depends on if it is a front loader, or a top loader. For both, machine not level front to back and left to right and / or not sitting firmly on all 4 feet.
Top loader, bulky load unevenly loaded.
Front loader, single bulky item causing an uneven load.
My washing machine top loader once reaches the spin cycle, with 21minutes time remaining, it goes back to rinse and repeats the cycle. What is the problem of my washer and how do I fix it? Thanks
If the washing is not distributed evenly by the time it reaches the rinse/spin cycle, it goes back to rinse cycle. Be present at the machine when it reaches the spin cycle. observe the drum to see if it is of balance and swaying to the sides, if so distribute washing evenly. Usually happens if there is a big garment or more with smaller items,
Regards
Phillip
1helpful
2answers
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
1helpful
My Kenmore he front load washer stopped at the rinse and spin cycle. I don't know the model but it only a few years old. It made a load noise before stopping. I attempted to get it going again wit
Kenmore front loader. stopped at rinse. First ck to see if you washer works at different settings if so its very possible its your timmer or what called the wig wag or solonoid this switches the machine to spin & rinse. A basic service call should resolve your problem.
1helpful
2answers
My Samsung WA75b9 toploader stops when the rinse cycle starts -makes noise but won't rinse or spin!
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
1helpful
2answers
Samsung front loan washer makes knocking noise during rinse cycle.
I have had a repair guy out for a separate issue and been told my knocking noise most prominent during rinse and spin is the bearings going. I have a samsung WDJ1225c front loader
4helpful
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
1helpful
2answers
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
