You use:
- "1" key to enter first digit of code (i.e. if first code digit is 5 you have to push "1" until it shows 5 on your display)
- "2" key to enter second digit of code
- "3" key to enter third digit of code
- "4" key to enter fourth digit of code
- "6" key to confirm code
Do you want the instructions of how to enter your code?
Turn the ignition ON.
Press the power button on the radio. The display will show "- - - -".
Enter the four digit code by using the and rocker buttons. The numbers will start at 0 0 0 0 and will increase on the display each time the corresponding side of the rocker button is pushed.
Press the down arrow side of rocker button to change left digit.
Press the up arrow side of rocker button to change second to left digit.
Press the down arrow side of rocker button to change third digit.
Press the up arrow side of rocker button to change last digit.
Push the AM/FM button once the four-digit code has been entered correctly.
If the proper code has been entered, the radio will return to the armed mode and normal operation shall return. If the wrong code is entered, the display will momentarily show an error message and then return to display "- - - -" indicating that another try at the correct code can be attempted.
With the newer HD Security Systems using proximity FOBs where the key FOB needs to be close to the bike to start, this is now more important then ever. If the battery in your FOB dies and you have not set your Harley Alram Override PIN Code, you will not be starting your bike. It is just as important for those with oler Harley Davidsons with the push button alarm FOB. It you set your alarm and the battery dies before you return to your bike, again you will not be starting the bike.
If you haven't set the PIN over ride for your HD security alarm system...do it now! Here's how you do it...
(To view how to deactivate the security system with the manual PIN code, see below.)
Setting or Changing Your Security System Alarm Override PIN
Button less fobs (Smart FOB)
1. Select 5 digit code ( each digit being a 1 thru 9) and record it on the wallet card in the owners manual.
2. With an assigned FOB present, turn IGN key ON - OFF - ON - OFF - ON
3. Press Left turn signal switch 3 times.
4. Press Right turn signal switch one time and release.
*Turn signals will flash 3 times. Current PIN will appear in the odometer. The first digit will be flashing.
5. Enter first digit (a) of the new PIN by pressing left turn signal (a) times.
6. Press right turn signal 1 time and release.
*The new digit (a) will replace the current in the odometer window.
7. Enter second digit (b) of the new PIN by pressing left turn signal switch (b) times.
8. Press right turn signal 1 time and release.
*The new digit will replace the current in odometer window.
9. Enter the third digit (c) of the new PIN by pressing left turn signal (c) times.
10. Press the right turn switch 1 time and release.
*The new digit (c) will replace the current in the odometer window.
11. Enter forth digit (d) of the new PIN by pressing left turn signal switch (d) times.
12. Press the right turn switch 1 time and release.
13. Enter the fifth digit (e) of the new PIN by pressing left turn signal (e) times.
*The new digit (e) will replace the current in the odometer window.
14. Press the right turn switch 1 time and release.
15. Before the module rearms, turn ignition key to OFF.
* The odometer will return to mileage display.
**Turning the ignition to OFF stores the new pin in the module.
Push Button fobs
4. Press button on fob twice
5. Enter first digit of the new PIN by pressing left turn signal until the desired number appears.
Press button on fob twice to enter number.
6. Enter second digit of the new PIN by pressing left turn signal until the desired number appears.
7. Enter third digit of the new PIN by pressing left turn signal until the desired number appears.
8. Enter forth digit of the new PIN by pressing left turn signal until the desired number appears.
9. Enter fifth digit of the new PIN by pressing left turn signal until the desired number appears.
Turning the ignition to OFF stores the new security PIN.
Using the Security Alarm PIN Override to Start Your Harley Davidson
1. Turn the IGN key to IGNITION and immediately hold both turn signal switches until 5 dashes appear in the odometer window.
2. Enter the first digit of your PIN (a) by pressing the left turn signal switch (a) times.
3. Press the right turn signal switch 1 time to move to the next digit.
4. Enter the second digit of your PIN (b) by pressing the left turn signal switch (b) times.
5. Press the right turn signal switch 1 time to move to the next digit.
6. Enter the third digit of your PIN (c) by pressing the left turn signal switch (c) times.
7. Press the right turn signal switch 1 time to move to the next digit.
8. Enter the forth digit of your PIN (d) by pressing the left turn signal switch (d) times.
9. Press the right turn signal switch 1 time to move to the next digit.
10. Enter the fifth digit of your PIN (e) by pressing the left turn signal switch (e) times.
11. Press the right turn signal switch 1 time to move to the next digit.
12. Press the right turn signal switch one time and the security system alarm is turned off.
The code goes in exactly how you would set the clock.If the code is correct the radio will unlock. It should be a 4 digit code.If its the 6 digit that is the code that needs to called into to GM for the 4 digit code.
1 Enter Standby
Press the [SRC] button.
Select the "STANDBY" display.
2 Enter Menu mode
Press the [MENU] button for at least 1 second.
When "MENU" is displayed, "SECURITY" is
displayed.
3 Enter Security Code mode
Press the Control knob for at least 1 second.
When "ENTER" is displayed, "CODE" is displayed.
4 Select the digits to enter
Push the Control knob to [4] or [¢].
5 Select the Security Code numbers
Push the Control knob to [FM] or [AM].
6 Repeat steps 4 and 5, and complete the
Security Code.
7 Confirm the Security Code
Press the Control knob for at least 3 seconds.
When "RE-ENTER" is displayed, "CODE" is
displayed.
8 Do the step 4 through 7 operation, and
reenter the Security Code.
"APPROVED" is displayed.
The Security Code function activat
if you have your code and need to know how to enter the code , it should be as follows .
Unlock procedure for six digit codes.
Push the "Hr" button, 000 will appear in display. Press the hour button
until you match the first number of your unlock code. For second two
digits of unlock code press the "Min" button until numbers match. When
first three digits of unlock code is entered into display, push the AM/FM
button. Repeat the above process for second set of three numbers of unlock
code.
if you need more assistance, post comment before voting thanks .
This solution is close, but not accurate for my 1998 A4 2.8. You press and hold FM2 and RDS until the display indicates 1000. Immediately release. Then enter code with radio numbers 1 through 4, pressing each one till you get the first no. of the code, then for 2, press till you get second no. of code, etc. The press and hold FM2 and RDS until radio comes on.
If I understand your post right, you have the code but need the procedure on how to input/enter it into the radio. To my understanding, a 1995 Volkswagen Passat would have a non-BOSE unit with or without CD changer controls. It was a premium sound system with anti-theft coding.
Pls try: 1. Power the radio ON till "SAFE" is displayed; 2. Press the AM/FM and SCAN buttons simultaneously till display shows "1000". (In some versions, it is the seek and the two scan buttons); 3. Release the AM/FM and SCAN buttons; 4. Enter your security code using the first four station buttons on the radio; 5. The first button changes the first number of the four digit code; 6. The second button changes the second number and so on and so forth; 7. Once the proper code has been entered press the AM/FM and SCAN buttons at the same time and hold until the radio accepts the code; 8. You have two tries before the system will lock you out for an hour; 9. Should you happen to have a three digit code, pls make the first digit a zero; 10. The first digit can only be 1 or 0 (the 0 will not show up so for a zero, push the button until the 1 disappears).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
