Kodak Easyshare C182 12MP Digital Camera Logo
Posted on Mar 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kodak Easy share C182 Digital Camera
Product: Kodak Easy share Digital Camera code: C182
Problem: When switching on ''Lens Error 211'' appears and it gets switched off.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Apr 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
941
Points
6
Please check that you have putted kodak alkaline batteries.
Anonymous
Level 1:
New Friend:
  • Posted on Mar 30, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2884
Points
Turn off. bang it slightly hard on your desk. turn back on. has fixed mine twice that way so far....
  • Anonymous Mar 30, 2013
    turn off. bang it slightly ******* your desk. turn back on. has fixed mine twice that way so far....
    hard*
Anonymous
Level 3:
President:
  • Master 1,194 Answers
  • Posted on Mar 03, 2010
Anonymous
Master
Level 3:
President:
Answers
1194
Questions
Helped
307808
Points
3666
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Turn OFF the camera. 2) Remove the memory card from your camera. 3) Reinsert the memory card, then push down on the card until you hear a click. check the memory card is firmly fitted in your camera. 4) Turn on your camera.
If your device got switch OFF quickly, then check batteries and make sure that they have sufficient charge, the batteries may need to be recharged or replaced.
Rating the Solution is highly appreciated..Good Luck
Lens error 211
Here is a video summary of troubleshooting steps for this problem.
Kodak Easy Share Camera C160 -keep going on and off code 211
This error message is related to a lens error from the information that I could find. In these instances it will typically require the repair or replacement of the lens assembly. I would find a local electronics store that can give you an estimate for free, but ultimately weigh that cost against the cost of purchasing a new camera.
Kodak Easy Share C182 camera is telling me to remove protection to delete pictures. How do I do this???
There are several possible causes for "memory card locked/protected", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
1helpful
Still getting a lense error 211 on my Kodak easy share c182 camera.....haven't even barley used it eather!!
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
1helpful
My daughter just dropped her camera, now the silver part/zoom lens wont go back in and its says, lens error 211. i tried removing the batteries and putting them back in but nothing has changed. what do i...
The lens has been damaged, or knocked out of alignment. There is a tiny motor that extends and retracts the lens, you will need to take it to a camera technician to assess whether it can be repaired or replaced.
5helpful
Lens error: 211 easy share c182
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
1helpful
Lens error 211
Good day,
This is a common problem and sometimes can be fixed.
Please see details on my tip on how to fix this error here:
http://www.fixya.com/support/r7041378-digital_camera_lens_problems
Let me know if my tip was useful for your problem!
Regards
6helpful
3answers
Kodak easy share c182"lens error 211" will not
I went with other advice, gentle drop on carpet sorted it :-)
2helpful
2answers
I need a manual for the kodak easyshare c182 12mp. can u help me. u can sent it to me in my e mail
You can download one from the manufacturer's web site at http://www.kodak.com
Simply go to the Help Center and select your camera.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
