When I try to print documents,an error occures.The error printed on page is:
PCL XL error
susystem:text
error:insufficentmemory
operator:text
position:902
How can I fix it???
I have the correct solution of this issue. You can save your precious time by just visiting the link given below.
I can't post the whole solution of the issue here, so go through the link.
https://www.hpsupport365.com/blog/how-to-fix-pcl-xl-error-on-hp-printer/
Finding ways to update drivers in your Windows 7? It's a good habit of checking driver updates for your computer. But it is a time-consuming task for you to check every update for your device drivers . In this article, I will tell you an easy way to keep all your Windows 7 drivers up-to-date automatically.
OK fine Hp printer 3050 has some error in Xp you can fix it by downloading the new driver for it . Uninstasll the installed driver and install the new driver it will fix the problem . again the problem presist you have to call the hp for replacement .
thank you
We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 bit edition is sending files to print (using the secure print function) - the system is reporting they have spooled fine to the printer - but when they go and release the document they are getting (more often than not) about 16 out of 21 pages (for example) and then a PCL XL Error (Subsystem: Text, InternalError 0x50, Operator: Text, Position: 8564). I have another document that 9 times out of ten will actually crash the WorkCentre completely and cause it to reboot mid way through printing.
The driver we are using is the latest: "Xerox WorkCentre 7655 rev 2.0 PCL6"
As mentioned the user is running Windows 7 - the printer is shared from a Windows 2003 Server which has the same version of the driver.
