Question about Zebra Symbol MC75 Handheld Mobile Computer Portable Terminal
Connection time-out issue with Motorola MC75 Handheld
I am using the Motorola MC75 handheld with the Rogers network. The issue is, when my handheld is idle the data connection is lost and I have to connect manually again - which is very annoying.
When I connect to my data connection using 'Internet Sharing', I connect properly. I use a software program that transmits data to a server backend and it works in real-time when I send the info. This works perfectly when I first connect and all consecutive transmissions I send. However if it is idle for roughly 5 minutes the data connection seems to timeout and I have to manually connect using 'Internet Sharing' again. Is there a way to stop this time out and have the data connection constant? It gets quite annoying having to go and connect again.
PS: connected or not, I cannot browse the internet using Internet Explorer either. (ive tested it out on the Telus network too, it isn't a network problem)
6ya staff
SOURCE:
Anonymous
  • 53 Answers
SOURCE: Can't connect via Bluetooth connection problem
print a configuration label from the printer to get the BT settings, you may need to use "label vista"(zebra) to configure it. the keys are generated based of the BT mac
Posted on Nov 09, 2007
Anonymous
SOURCE: LP2884 not recognize by one of the computers
Make sure you download the Zebra Designer Driver for the Vista computer. The Zebra Universal driver does not work with Vista. Vista Driver Link
Posted on Mar 11, 2009
Anonymous
SOURCE: how to integrate LS2208 handheld scanner in vb.net
you have to change it to IBM handheld mode and install opos drivers from symbol. then use pos.net to connect to them.
Some computers requires to create some config files to connect through hardware address. It took me like 6 month to figure out but now it works
Posted on May 18, 2009
RoryMRP
Rory Cardenas
  • 111 Answers
SOURCE: Printing loop
Have you tried sending print jobs thru the parallel port only? I think it has to deal with your jetdirect box. You can try reseting that as well.
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Posted on Jul 07, 2009
Anonymous
SOURCE: Zebra LP2824 Not Printing
I had the same problem and could not fix it but called Zebra headquarters and they gave me this solution and it works! It sounds crazy but it works. Turn off the printer on the switch on the side. press and hold the button on the front of the machine while you turn it on. The light will turn red then release the button the light around the button will then turn a solid greed then blink green. While it is blinking green press and hold the button again until it the light turns orange and then release the button. This apparently puts your printer into line mode or something but anyway it works!
Posted on Aug 05, 2009
ITS ON A FROZEN SCREEN HOW DO I GET IT OFF??
Contact Motorola Solutions. Http://www.motorolasolutions.com/support
Jul 23, 2014 | Zebra MC75 Wireless Handheld Barcode...
What can be the cause of my handheld that is showing avalanche mode and can't connect?
I would go to www.motorolasolutions.com to find your answer.
May 08, 2014 | Motorola MC75
No signal on motorola mc75 scanner when in metal building
Information regarding metal building may well be correct as metal buildings can act as a farraday cage blocking radio signals.
Mar 21, 2014 | Motorola MC75
Beep barcode
how i get driver for scanner umax astra 4100
Nov 06, 2013 | Zebra MC75 Wireless Handheld Barcode...
How to factory default Mc75 device
Resetting the MC75
There are two reset functions, warm boot and cold boot. A warm boot restarts the MC75 by closing all running
programs. A cold boot also restarts the MC75, and also resets the clock. Data saved in flash memory or a memory
card is not lost.
If the MC75 is not functioning properly, perform a warm boot first. If the MC75 still does not respond, perform a cold
boot.
Performing a Warm Boot
Hold down the Power button for approximately five seconds. As soon as the MC75 starts to boot release the
Power button.
Performing a Cold Boot
To perform a cold boot simultaneously press the Power button and the 1 and 9 keys.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 01, 2011 | Motorola MC75
I installed Datawedge.exe in my MC75 device. How can I read barcode using this software?
We have set up many of these device with Datawedge. The configuration depends on what type of barcodes you want to read. Contact me www.datexcorp.com and we can walk you through it at no charge
Mar 17, 2010 | Zebra MC75 Wireless Handheld Barcode...
Is there a way i can unlock my blackberry pearl flip for free? im on the rogers wireless network in canada
To unlock the handheld from the Rogers wireless network in canada, you need to complete the following steps:
1. Turn all connects off(manage connection).
2. Select Options.
3. Select Advance option.
4. Select sim card.
5. Type MEPD.
6. Type MEP2.
7. Type the Unlock code.
8. Press enter.
You need to contact the customer care of the service provider for unlock code.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 04, 2009 | RIM BlackBerry Pearl Smartphone
IPAQ 1950 suddenly will not connect to PC to allow sync
Same problem, on four computers with two iPAQ 1950's. I installed ActiveSync 4.5, and all works fine now. This link will get you to AS 4.5:
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/activesync-register.mspx
This SHOULD work for all PDAs, but I have only used it for the 1950.
Nov 11, 2008 | HP iPAQ rx1950 Pocket PC
Zebra Symbol MC75 Handheld Mobile Computer  Portable Terminal Logo
697 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Lawrence Oravetz
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
