Please help I need to unlock my phone and sim need reset codes please please please
Write your answer...please help me i forget simlock password for sumsung D900i
If your phone is saying SIM LOCK enter password
then the reset codes wont help you,
if the phone is saying phone code enter password
then this code will help you
*2767*2878#
if it is saying sim lock,
then u need to take it to samsung or a service technician with a pc, he will unlock it for you in about 3 seconds
quote:@
Guest
Rank: Apprentice
Rating: 0%, 0 votes
"you can unlock your phone (ie allow it to accept SIM cards from any network) using the ''full reset'' code - *2767*3855#.
Hope this helps"
this solution is to erase the date and the eprom reset,
it does not however remove the simlock :o
DATA*
How to unlock the sim code?
You can unlock your phone (ie allow it to accept SIM cards from any network) using the ''full reset'' code - *2767*3855#.
Hope this helps
SOURCE: reset phone lock code
Hi, Very simple & quick way to unlock your j700 without any box or
cable
just enter #*7337#
your phone is unlocked
SOURCE: PHONE UNLOCK
Unlocking
the E900 is easy..
This phone is fully supported by the SRS server.. More than 2000 phones are already unlocked by this system
you only need to connect your orriginal data-cable to the computer. run the unlock client, login and press the unlock button..
wait 15 seconds.. and youre done..
more info: http://www.UnlockSamsungOnline.nl/eng
Hope my info solves your problem.....
SOURCE: forgot SIM lock
Did you try so called "puk" codes? If you did this that I'm afraid you will have to visit your operator. :(
I typed in some kind of code which didnt allow me to use my original sim card anymore. when i put my sim card in it tells me " no Network". however my sim works in a different phone
forgot my security code and need to unlock it, misplaced my proof of purchace
MAS SAYA LUPA KODE KUNCI SIM.SAMSUNG DUOS GT-C3312 TERIMA KASIH.
locked my sim card and now phone will only make emergency calls. I need to factory reset if possible and reset Sim card info if needed
I need PUK and PIN# to unlock my phone. Please help.
