I have a 2003 WS65 HDTV the tv worked fine I was moving and had no room where I was going to be so I put the tv in storage for 3 months ,got it out moved to apt.Now when I plug it in ,the power light comes on for 2-3 seconds and then blinks twice and turns off, could something have gotten loose in the move? I had the exact same tv but 45 in model again working fine moved to new location did exact same thing once there sold as is before fixing.Is there a problem with these tv's that they can'nt be moved?
TV may have simply lost the ch4 frequency from memory.
My TV did this 2 months ago and it blew me away as all other stations were fine.
Put it down to Cosmic Rays!
Simply run the Automatic Station Finder from the main settings menu. This will reload all receivable stations back into it's internal memory storage again.
Other than that.... is ch4 still on air.
Does the wifi work fine on other apps?
Be sure you have saved your account info on the tv. More so, entered correctly.
You should be able to refuse the 3 months and proceed at least in demo mode or something.
Perhaps there is a way to reset the tv info or apps.
I have found on some apps with my vizio I had to unplug the tv and restart because the app had hung up.
Worth a try.
If Downton Abbey is available on "instant watch",, it will work through your tv.
No,this thing come in as a whole tv unit,dosen't come aparts.U check the tv,see if it work,before going all the troubles moving it to another room.These DLP tvs design are notorious for it tv convergence problems and DM power supply board intermittently shutdowns alots.It bulky design and not work for free DTV over the air.
As you are able to go to internet from room 3 through the same cat5 cable then i dont think its a cable issue. Please check Storage device if there is any access permission/deny needs to be configured. If that doesnt help , you can try once by interchanging the cables between the one going to room2 and other one going to room3.
I remember Jvc put out a service document about changing 2 transistors in the power supply..they are surface mount on the solder side of the pcb. You might not find the parts anymore unless your very tech saavy. Sorry man..
Hey! I have the same problem as you. But! this would happen only when I got a power outage. Unplug the TV for a couple of minutesand all was fine. For the last 5 day I have no TV. I have tried everything. All the out on the TV and I still get unusable signal. My rep told me to unplug for 24 Hours. Still didn't work. My menu option work as well and every time I put the TV on, off or if I change the input sound will come on for 2 seconde and stop. If I find the salution I will let you know.
Gilles Ottawa
