If the cable is broken, you should just be able to replace it. The cable comes with a "mushroom type" button at the top that will slide into the "actuator" Take off the 2 screws on the back compartment just above where the power chord goes into the machine. The top of the handle will slide off toward the back of the machine and you can see where the cable connects and how the power switch is activated.
Try standing the vacuum on end, or at a near vertical position, and gently tugging on the cord a few times. This will usually cause it to retract. The problem is usually caused by pulling the cord out too far. Avoid doing this as it can result in disconnecting or breaking terminals and/or wiring.
Yes, there is. It's a small white button located near on the back, near the left wheel. Unplug vacuum, then use the end of a paper clip to push in and reset.
I have a charger that is lableled
Shark V1917 APL1172 AC Power Adapter
Model KA12D120015023U AC Adapter Power Supply for models V1917 & APL1172
if this will work for you please let me know and we can work something out. Someone is selling this on ebay for 39.99 but Im open to offers. Please email me at [email protected]
thanks
Ok, lfitz, I fixed my problem. First I called the Sears Service Center. They told me that I would have to drop it off there, and they would send it to Orlando to get looked at. The whole process would take about 2 weeks and who knows how much money. So I decided to become my own Hoover technician. It turns out that my original diagnosis was right about the chord that electrically connects the power on/off switch at the top of the handle to the rest of the vacuum. This was extremely easy to fix so please don't be scared away, although it does require a little philips-head screwdriver action. As always, make sure the vacuum is unplugged before you start. On the back of the vacuum, there is the hook that you wrap the electrical chord around for storage (the top one). On either side of that hook are two screws. Unscrew those. Now, the small piece of plastic that has the hook on it can be carefully pulled back, or removed if you need to. Inside, I found the detached end of a coiled black electrical chord that looks kind of like an A/C adapter. This chord should be plugged into the bottom of the metal shaft that slides in and out to allow you to adjust the height of the handle. Now, adjust the metal shaft so that you can plug the black chord back into the base. Push the chord in until you hear it click. Now, put the plastic piece back in place and put the screws back in and you're done. Plug it in and give it a try. I hope this helps.
