When the problem is happening, you need to check to see if you've lost spark or fuel. when you try to restart the car,can you smell gas? if you can,you need to pull off a spark plug wire and put a screwdriver into the end of the wire. set it down 1/4" or so from a metal ground. have someone crank the engine, see if there is a nice strong spark. if so, you're fuel pump is probably faulty. it's inside the gas tank
