Washing Machines Logo
Posted on Feb 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bosch 500 series washer E:27 error code? - Bosch Washing Machines
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2069
Points
Bosch washer error 27!
Anonymous
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Jun 14, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
28733
Points
10
Just fixed the E27 error code. Just turn dial to off and hold down delayed start button and spin selector button and turn dial to the left one click (cold). It should then click and open. open the door and turn back to off. Everything should go back to normal.
Steven Clarke
Level 2:
Sergeant:
  • Expert 222 Answers
  • Posted on Nov 16, 2011
Steven Clarke
Expert
Level 2:
Sergeant:
Answers
222
Questions
0
Helped
141512
Points
567
Error 27 is the door lock, unplug machine for 30 mins or so, then replug, possibly closing the door too hard messes up the sensor/switch in the door lock assy, if all else fails replace door lock.
3 Related Answers
Anonymous
  • 414 Answers
  • Posted on Jul 12, 2010
SOURCE: Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
richroth
Richard Roth
  • 9472 Answers
  • Posted on Nov 21, 2010
SOURCE: Bosch 500 series washer E:27 error code?
E27 means there is a problem with the door lock. Unplug the machine for 5 minutes and try again. If the error code returns you will need to replace the door lock assembly.
Anonymous
  • 8 Answers
SOURCE: e:27 error on bosch 500 series washer
turn the dial to the off position. Hold down both the delayed start and spin select buttons and turn dial to the left one click (cold position). you should then here the door unlatch. let go of the buttons. you will see some other codes p 01, p 02. turn dial to off. it should work fine after this. it worked for me. this should be in the manual.
2answers
5helpful
2answers
E:27 error on bosch 500 series washer
34helpful
4answers
turn dial to off. hold down both delayed start and spin select buttons and turn dial to the left one click, to the cold position. keep holding button until you here a click. let go of buttons and turn dial to off. Every thing should go back to normal. Just fixed mine and all is good.
Error code E:13 on my 500 plus series washer
The E13 error code on your Bosch washer refer to a drainage problem or the pump time might have been exceeded
Either it might be due to a clogged pump, improper detergent being used, ( must use "HE" detergent ) hence suds not allowing a proper drain cycle. You should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. First run the short wash or refresh cycle without detergent and hopefully your lines will clear.
Thank you !!
Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
