Expert
- Posted on Mar 02, 2010
Re: My 1999 cougar alternator stopped charging also no...
If you get no red light for the battery charging system the charging system will not work. The indicator light initally excites the field to start charging.
yes i have checked all fusses ,under the hood and cabin fusses they all seem to be ok ,but i never did recieve a owners manual so i dont know what fuse is for what.the car will start when the battery is chargedbut when i put the amp tester on it shows not charging,unhook the battery terminal the car stalls.(this is a brand new alternator not a rebualt)so no charging ,no speedometer,no techometer no fuell or themperture guagesand no lights in the dash when the key is turned on beforecontinuing with key to start car.this happened at the same time the alternator stopped charging tested the fusses and relays and i cant seem to find the problem even thought ive worked as a mechanic my self for over 20 years.this one has me really confussed think you can help
Have you checked all the fuses and relays? There may be a fuse box in the cab somewhere and there's usually one with larger amp fuses under the hood.
does your battery come on when you turn the key to start it?(light check)
