Hi
You need to run the Disk utility and format the drive first.
You will find disk utility in the applications folder then the utilities folder if I remember right.
Format the drive, make sure its set on the MAC OS setting, journaled if I remember right.
It should work after that, all content in the drive is lost if any is there.
Plug your USB imoga ego usb drive into your computer.
Click on the "My Computer" icon at the top of your computer screen.
Double click on the iomega USB icon.
Right click in a blank space in the middle of the window to pull up a small menu.
Select the "New Folder" option from the menu to create a new folder on your Iomega USB 2.0 drive.
Drag all of the files that you want to protect into the new folder you created.
Right click on the folder that you created and select the "Properties" option from the menu.
Go to the "Sharing" tab and click on it.
Scroll down to the "Make This Folder Private" box and check it. Click the "OK" button and wait for the window to close.
Use your Windows log-in password to open the file.
hope this helps
