HI, I have a Kenmore 25813 and it seems like there is an intermittent short. When I have the extension wand on and the power floor attachment on, when it rotate the wand the light cuts out and so does the power floor attachment, when I twist it back it comes on again. I don't have this problem if I remove the wand and just use the crevice tool with the hose. Any idea where the short might be and can I fix it myself? Thanks. Gary
You need to remove it by pressing the tool attachment button as hard as you can and then slide the cuff off. I needed to use a screw driver to press the button down and then slide the cuff over the button with the screw driver as a wedge. Once the cuff is off, everything else is easy.
HI There,When a Kenmore power nozzle cuts on and off, this usually indicates that your electrical hose has gone bad and has a short circuit somewhere.You can try and troubleshoot the hose to find out where the short is by trying to determine what position the hose is in when it cuts on and off, and try to isolate the short circuit by spinning the hose on both the end that plugs into the canister, as well as the end that plugs into the wand. Sometimes the short is in the wands, or even the swivel neck assembly on the power nozzle where the wands connect.I would say 9 times out of 10 though on Kenmore canisters, the problem is in the hose. Kenmore is actually manufactured by Panasonic, and the two brands use a lot of the same identical parts, including the electrical hose (most cases).If your Kenmore has a two position switch, with a setting for floors and carpets, then here's a link to the corresponding Panasonic hose that you can buy. The Panasonic hoses are a little more expensive then Kenmore, but the huge benefit is that they come 100% completely assembled, where as the Kenmore hose has to be assembled (which is extremely difficult even for me to do).Panasonic 3 Wire Electrical Suction Hose To Fit Kenmore CanistersOn just a handful of Kenmore models, an additional modification has to be done with the internal switch. Kenmore must have had the hose modified so you'd have to buy the genuine Kenmore part, but luckily simply switching two wires on the switch will allow the Panasonic hose to work. Try just plugging in the hose into the vacuum first, and if it still doesn't work properly, then you can modify the switch.
If you find that the short is in the wand or swivel neck, just use the comment field on this repair page and let me know, I'll be happy to follow up and walk you through either of these repairs as well. If this was helpful to you, please be so kind and rate the repair, or leave some feedback for me. This is greatly appreciated.Chris JonesGoVacuum.com
Check your lower and upper wand connects for pinkish or blackened evidence of burning. All connections should be shiny clean brass. Polish with wet dry # 600 paper or a scotch abrasive dish pad.
If the junior runs, with its tighter, cleaner less used connections it is very likely the wand connections and mating component, either the hose handle or power head elbow are also burned or badly worn. On a Kenmore, due to the weight of the head and mediocre design they wear in pairs and should be replaced in pairs. You can get some electrical parts thru a Whirlpool FSP parts center or a Panasonic dealer if you take in the matching pieces for clarification
The neck in your power head is likely clogged. Disconnect from the wand and look inside. Also check the wand.Since you have suction on the bare floor the hose is likely not blocked.
Check the plug ends at the top of the wand and the plug going into the hose handle, also at the bottom of the wand. It sounds like they may be burnt, if so they will need to be replaced. One cause of these connections going bad is not turning the power head off when connecting or disconnecting. Therre are other causes, the switch in the handle is going bad, also some of these cannisters have a relay mounted by the vac motor, sometimes they go bad.
if you have an extension wand, the replacement will cost about $100.00. there is a way to repair both the pwr-cord on the brush assemble and the wand, but it depends on how much damage there is. also you need to check the contacts where the wand connects with the handle,and the prongs on the handle.
