select file in the top left hand corner then select print preview from the drop down list there should be another drop down list in top left hand corner with percentages
30%
40%
50%
etc....... this is on a web page
the same should be on the page if you have made a word document
if you are using word open up word select view from the drop down list select toolbars select standard formatting
also open up word across to the left you will see arial,times new roman,arial black next will be more to name a few of the different languages from the drop down list your documents will be read in
also next to that will be a drop down list with all sizes you can change the sizes of text
open up a document you should a number of tabs at the top of your screen you should see a number with % percentage with a drop down list which has many zoom increases
if you are using a word document to open it on the top select the format tab open it then select font you can change your settings there also across the left you will see a stencil and an A which have drop down lists of color changes for background and print
hope this helps
if you are trying to get the songs from itunes to your computer you will need an ipod to computer transfer program or you can back them up to disks
open up Itunes in the top left hand corner select file from the drop down list select library then you will have options to back up to disc organise library export library import playlist?and export playlist??
open Itunes in the top left hand corner select file from thdrop down list you will see Library click to open then you should see back up to disk then more options back up entire library to disk
hope this helps
