The flash is suppose to help with the lighting situation in order to lower the chances of you taking blurry pictures. Usually indoor pictures must have the flash go off in order to get clear pictures. If your outdoor pictures are also coming out blurry then you probably have some problem with the lens. My first suggestion is for you to go into the menu and reset all functions to default. You will have to read the manual to find which menu it is in, but I guarantee you that it is in the camera menu. If the reset does not fix your problem then the lens is probably out of position or damaged in some way. You would need to send into an authorized service center for repairs if this is the case. I know that Photo Tech in NYC is authorized for Nikon repairs. www.phototech.com is the contact info.
Instead of green auto mode set to P mode and chagne the flash setting to non auto.If flash is is in auto mode flash will not fire and picture will be blurry.So your flash must fire every time (and it must not be decided by camera's auto flash mode). I am sure this will solve your settings. Please rate if satisfied.
This is a menu setting, in capture mode it is the slow synchro option I think. What it does is try to get the subject to have a lit background. Turn this off and you get a subject lit with flash and no background but no blurriness either.
Set the camera to anything except no flash. Turn it off. Take out the battery. Wait 5-10 seconds. Put the battery back in. The flash should now work until you turn the camera off again (and then you must remove/replace the battery to get the flash working again).
The flash requires some kind of "master reset" to work. Haven't found a permanent solution to this.
Make sure your subject is within the camera's range. You should be at least 31 inches away to take a picture without the flash, and 31 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode. When you take macro close- ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. Try increasing the shutter speed. For more information, see Chapter 6. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
