Everytime i used my computer after 10 minutes it becomes black then appears on the screen "not optimum mode recommended mode 1024 x 768 60hz" what the problem????how???
Change windows resolution and refresh rate to 1024 X768 and 60 Hz. start->control panel->display->settings-> change the screen resolution to 1024 by 768 pixels-> advanced-> monitor->change refresh rate to 60 Hz-> ok-> yes -> ok.
Sometimes
all it takes is a restart for the iPhone to become responsive again. To
restart your iPhone when it is unresponsive, press and hold the
sleep/wake and home buttons until the Apple logo appears (~10 seconds).
Very low battery
It
is possible for an iPhone to become unresponsive if the battery drops
to an extremely low level. Plug the iPhone into your computer or wall
charger and allow it to charge for at least 20 minutes before using it
again.
befor loding windows press F8 then choose vga mode
inside vga mode change the resolution to the recommended mode and restart your pc
then i think it will works
bye
dont forget to rate my solution
OK. IN XP GO TO DEVICE MANAGER AND CLICK ON THE MONITER AND UPDATE THE DRIVERS.IF IT TELLS YOU IT CAN NOT FIND A BETTER DRIVER UNINSTALL..REBOOT AND DOWNLOAD NEW DRIVERS FROM CO. WEB SITE.RICHARDM69
this is not the problem with your monitor. Pl boot your computer with enable vga mode. in vga mode set your resolution into 1680 x 1050 with which color mode you need set ok
it will be ok. After restart, your computer will ok. even the problem retains, pl reinstall the video driver and try again. give me ur feedback
Hook up a different monitor and set resolution to no higher than 1024 x 768. Samsung monitor will then work fine. It appears that something fails in the monitor and it will no longer support anything higher than this.
