I had similar problems when I first started sewing. Try adjusting the tension in your thread - less tension for lighter fabrics, more tension for heavier fabrics. This will stop the needle from pulling the threads in the fabric.
As for the thread getting bunched up in the bobbin - this is most likely because your bobbin is the wrong size for the machine, or that you did not thread the bobbin properly. Try re-threading, this time making sure you pull the thread into the bobbin container tightly. This should stop the bobbin from jumping around the container and spitting thread.
