Here is service manual for HP 1160/1320 series ->http://filecom.net/CXW_R.
Solution is on page 34. I hope it will help you.
LaserJet 1320
This light pattern indicates a fatal error condition. This condition may be resolved by unplugging the unit for 5 minutes. Plug the printer back in and observe the light pattern.
If this condition persists, HP advises contacting their support.
Details of the light patterns for the LaserJet 1320 and their corresponding error conditions can be found at the link below from HP support:
HP
LaserJet 1320 Error Light Patterns
I hope this information is helpful.
SOURCE: fetal error on HP laser jet 1160
Hi naseeh83: Here your problem. Fuser error. The fuser has a malfunction. Try these steps. 1. Unplug the printer for at least ten minutes. 2. Verify that the fuser connector and thermistor connector are both firmly seated in the ECU 3. Perform a heating element resistance check. 4. If the resistance readings are correct, but the error persists, replace the fuser. You may have to call a certified HP technician to repair this printer. Hope this helps.
SOURCE: The printer has a solid green ready light, a solid
Try removing the jetdirect and power cycle the printer.
SOURCE: switch on the hp laserjet 1160, The Attention,
you may have a fetal error, press the button to see the secondary error code
