“My Toshiba
laptop suddenly shuts down by itself without any warning. Sometimes it
works fine for hours, sometimes it shuts down in 10-15 minutes.”
This complaint we hear from our customers over and over again. About
15-20% of all Toshiba laptops we get for repair, suffer from an
overheating problem. Yep, OVERHEATING!
This is one of the
most common problems with Toshiba laptops we deal with.
Indications of
laptop overheating problem:
Solution:
If the CPU heatsink is
not clogged with dust and lint completely, you can use canned air and
just blow it inside the laptop through the openings on the bottom and on
the sides. It’s nice as a precaution measure, but it might not work if
your laptop already has a problem and the heatsink is completely
clogged.
For this u buy laptop coolpad which will solve the problem. it has a fan fitted on which the laptop is kept.
SOURCE: laptop heats and shutdown
You should not use a laptop on a soft surface such as a duvet or bed covering. The device needs to have free air intake and outlet to cool the processor. If you block the intake, which is probably under the machine, it will overheat and shut down.
If you want to use it in bed put it on a hard surface such as a large book, so that the air intake cannot be blocked.
May be there is dust in your laptop. Use the laptop with some wooden flat surface instead of pillow, the laptop should heat less frequently
