Hi there Suvendup,
To do a FULL format, do the following:
1. Make sure your phone is fully charged to handle the formatting process.
3. Turn off your n70.
4. Press and hold the following keys at the same time:
a. Green dial key
b. * or the star key.
c. the no. 3 key
5. Press the power on to switch on the phone. Take note: Hold those keys until you see a formatting word on your screen.
6. Wait for a few minutes until formatting is completed.
Please let me know if this works for you. Good luck!
thanks dude i tried that i success them
thnx so much brooooooooooooooooooo::::))))
auto loudspeker
TANS SO MUCH
where can i get this security code please help
The code is *#7370# if this doesnt work try *#7780# but u will need security code
NOTE: U MUST HAVE FUL; CHARGED BATTERY WHIE DOING THIS OR CELL MAY GET DEAD
SOURCE: N70 Unlock code
if the security code was manually set by you,then there is no way to find that with imei or serial number...
reinstalling the phone software is the only way
thankyou
SOURCE: i wantformate my nokia n70 cell phone
dail *#7370# after that it will ask you to restore the factory setting click on yes
SOURCE: nokia n70 formating
try using the code:::
*#7370#.
it wil reset the phone.
but make sure you copy all you data and contacts from phone to memory card.
SOURCE: format nokia n70
hav u loaded many softwares on ur n70...many softwares stay active n eat up ur ram....softwares such as antivirus,autokeypad lock,fullscreen caller etc are always active on ur phone invisibly so u cant see them when u hold press the menu key but they r there nevertheless so its best to uninstall the not so frequently required softwares ...try to keep the phone mem as empty as possible...also upgrade ur n70 software from a nokia gallery.....that should make it fast!!!!!!!!!
You can format your Nokia N70 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
If it is not working try this code:
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Some Nokia phone can be reset via this menu option
Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YES
