Question about Tascam 2488mkii 24 Track Recording Workstation
Conn organ powering on but not playing any sound
  • Tascam Master
  • 5,603 Answers
Check for a problem with the expression pedal. Some have a light and photo resistor and lamp burns out.
Posted on Mar 20, 2010
6ya staff
SOURCE:
Can't find where to oil my conn threaterette organ
I do not beleive you normally oil a Conn organ, only tonewheel Hammonds require oiling.
Mar 22, 2018 | Conn Music
What makes it hum loud? Conn organ 71450
Could be failing power supply
Mar 26, 2017 | Conn Music
QS8 keyboard. Why is volume in organ mode much louder than piano mode when I switch between modes without touching volume slide?
On organ mode, in general, almost all brands of the modern keyboard, velocity setting is not enabled. Setting velocity is used to determine how much the level of the sound that follows how strongly you press the keys. It is really just to imitate the sound of vintage organs, which in the past, electronic organ technologi not use the velocity on the keys. So, how strong / slow we press the keys, the sound level will remain the same.
At the Piano mode,modern keyboard using setting velocity. This also to imitate an acoustic piano, which, if we press the keys slowly, the sound level will be slow as well, and vice versa.
So, in your case,at the same volume slider, try to play on the organ modes, note level. Moving to the piano mode and press the keys securely powered (full power). Then the sound level should be equal to the organ mode.
On modern keyboards, also included organ sound that added velocity setting. Usually found on the user bank.
Sep 01, 2015 | Alesis Music
Alesis QS8 keyboard. The volume of the organ is much louder than the keyboard when I switch between both modes without touching the volume slide. How can I fix this.
Theatrette 552 conn organ
I have manuals
Jun 03, 2013 | Music
We recently purchased a CONN Minuet electric
If you mean vacuum tubes istead of "lights" be aware that just because they light up doesn't mean they work.
MANY of them LIKELY are dual ones with two sections that both must be lit to work.
The starting point is to check power supply voltages.
Nov 06, 2009 | Music
Tascam 2488mkii 24 Track Recording Workstation Logo
271 people viewed this question
Top Tascam Music Experts
Michial Gueffroy
Lawrence Oravetz
Harrie
Are you a Tascam Music Expert? Answer questions, earn points and help others
