Video Cameras Logo
Posted on Feb 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you recharge battery where is the plug grd850u
Catalin Turcu
Level 3:
  • JVC Master 4,924 Answers
  • Posted on Feb 27, 2010
Catalin Turcu
JVC Master
Level 3:
Answers
4924
Questions
0
Helped
1231980
Points
13383
Almost all this dv cameras have a AC adapter and internal data battery so just plug the ac adapter and the battery will display when it is full ...it doesnt even need to be on when charging ...
Hello, After charging my Peak 300 Jump Starter it whistle's (loudly) after I unplug it and it just keeps whistling... Can you tell me what the matter? email:
Refer to the instructions that came with charger. If you threw them away you have a problem You can go on line and download instructions.
Low Charge Alert (LCA)
On the front of the unit there is a Low Charge Alert port. There is a red plug in this port. With the plug
removed, when the battery level drops to LO, an alarm will sound to remind the user to recharge the
Jump-Starter.
The alarm can be turned off one of three ways:
Placing the pin back into the Low Charge Alert port
Recharging the battery immediately to bring it to the capacity of 10% or more
Pressing the battery indicator display button. If the alarm is turned off by pressing the battery
display button, the alarm will sound automatically again in approximately 1 hour.
The alarm will only be turned off permanently if the battery is in a fully charged state, or the pin is
inserted in the Low Charge Alert port. There is a storage port on the back of the Jump-Starter for the
LCA plug. When the plug is removed from the LCA port, it should be installed in the storage port on the
back of the Jump-Starter.
Charging Jump-Starter Battery
All rechargeable batteries gradually discharge when left idle, and you need to recharge them
periodically to maintain maximum battery capacity. The AC charger plug within the Jump-Starter is
designed to charge using a 110/120-volt outlet.
Fully charge unit to the recommended maximum and initial charge time of 24 hours. Thereafter, an
AC typical charge time is 8 to 12 hours.
Recharge the unit fully after each use. This will prolong the life of the battery because frequent
discharges between recharges will reduce battery life.
Make sure all functions of the Jump-Starter are turned off during recharging
I keep getting battery has been exhausted on my LED screen after I turn on the camera.
It means you need to recharge the battery of the camera.
You can't recharge the camera's battery the same way you recharge a smartphone or a tablet, it probably won't recharge if you plug it to an USB port/recharger.
Take a look at the camera's manual, probably your camera came with a battery charger, and you need to open the camera, extract the battery and use the charger.
Take a look at the camera's manual.
Sep 23, 2018 • Cameras
Eton FR300 will not recharge
This is not a Camera
Dec 01, 2017 • Cameras
I don't know how to recharge the battery
Just to be clear: you can either buy the rechargeable battery or regular batteries of the same type. I'd rather get the rechargeable battery, saves a TON of money.
To recharge a battery, you need a charger for the battery - they come in plugs for the wall or for the car. Just place the battery in the charger, plug it in. It depends on the brand, but usually there is a little button that will glow red but when it is fully charged it will change to green.
I'll put a picture on here for you. The battery itself is "KLIC-8000". 12_19_2011_7_12_37_am.jpeg
To recharge my rechargeable batteries, do I plug into the back of the console and the top of the battery pack, how long does it take to recharge
to recharge your rechargeable batterie you plug the holder that hold the batteries into the wall, then a green light should turn on. That should help you out! :)
It takes bout in hour.
But thats how mine work
2answers
Dvd player recharger charge status lights blink
The blinking went away as I had charged it for a very long time. However, it was noted that it would not work on the DVD. The battery needs to be replaced. That solved my problem. I still have to look for a new battery for this device: US Logic 680p DVD player with recharging capabilities due to the portability option. It works fine if plugged in, but the battery just needs to be replaced if I want to use it independent of the plug. Thanks for asking how I resolved the issue.
2answers
Battery not recharging
All batteries die sooner or later. I believe you have a dead cell.
1) Find another machine that uses the same battery and try it or
2) try another battery or
3) Give up and buy a new battery.
Good luck.
1helpful
How to recharge battery of Olympus FE-280 Digital Camera
When you purchased the camera, there should have been a charge in the box (you got a lithium-ion rechargable battery with the camera, no?). You put the battery in the charger and plug the charger in the wall.
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
